01-02-2022, 05:26 PM | #23 |
Rep 692
Interestingly I made this change in bimmercode and I could swear I tested and it had worked.
However today I am driving at highway speeds and its again 3pm off. Are we sure this works? Also I know there is a similar coding with the word digital in it: BC_DIGITAL_V_KORRECTUR Makes me wonder if this is the proper one to change? |
01-02-2022, 06:13 PM | #24 |
Rep 714
My old '07 335i and this car are exactly the same, 80 mph = 75 MPH exactly. I also have the staggered PS4S's.
01-18-2022, 07:55 AM | #25 |
Rep 692
So i found out today that there are changes to be made in KOMBI 3002 WEG that will allow to adjust exact speedometer readings.
Problem is I don't see 3002 WEG entry in expert mode in bimmercode. If anyone has ISTA etc you can try applying this detailed fix: https://www.m5board.com/threads/corr...coding.430570/
06-05-2022, 01:55 PM | #26 |
Rep 193
In UK. Change this and it still under reads.
Current car: G20 M340i Black Sapphire (Stage 2 BM3 and xHP with Downpipe)
Previous cars: 2019 VW Arteon (Stage 1+), 2017 Audi TTS, 2015 Audi S3 Sportback, 2006 BMW 335i Coupe |
gnolivos319.00 |
06-05-2022, 02:31 PM | #27 |
1942
Rep 3,521
I haven't corrected it in my BMWs yet. I prefer it compared to my other cars where, in my Mercs, the speedometer actually under reads the speed by 2mph (speedo shows 100mph and actual speed is usually 102-103mph) and Audi/VW where speedo under reads by 1mph or is spot on (VW speedo shows 100mph and actual speed is 101mph but my Audis have been spot on).
06-05-2022, 04:40 PM | #29 |
Rep 692
Re: speed adjustment.
No known fix yet with bimmercode even on expert mode. Maybe with ISTA it can be done. I posted a potential ISTA fix that worked with previous f30 platform but no one has tried it.
06-23-2022, 08:17 PM | #31 |
Professor
2250
Rep 1,813
Drives: '23 M2 & '22 X3 M Competition
Found this thread after noticing my Speedo reads 3 mph high. Fwiw all my other vehicles read dead on, so this one reading high is really not something I want, or should have to deal with. Is this not something that can be recalibrated by the dealer?
*19" staggered M 791 wheels. |
06-24-2022, 09:45 AM | #32 |
Rep 1,687
I was zapped by a roadside officer this morning
I had Driver Assist engaged and was showing thirty, the roadside display of my speed said 28.
06-24-2022, 06:42 PM | #33 |
Rep 137
Its part of the premium German car experience. Its so well built that going 75 really feels like you're going 72.
But, seriously, its "normal" in that all our BMWs do this. |
06-25-2022, 06:40 AM | #34 |
Professor
2250
Rep 1,813
So whether or not owners accept this (stupid, imo) quirk as being normal, I'm assuming it should be able to be corrected by the dealer, just as one would need to recalibrate the speedo for a wheel/tire size change?
gnolivos319.00 |
06-25-2022, 07:28 AM | #35 | |
Rep 692
06-25-2022, 09:26 AM | #36 |
Professor
2250
Rep 1,813
If it is a safety feature, it seems more vehicles would be configured this way. In no other vehicle I've owned (36 to-date) has the speedo been off. Curious, if I were to change from the OEM 19" wheels to say 20" wheels, we're saying there is currently no way to calibrate the speedo to account for this?
06-25-2022, 09:39 AM | #37 | |
Rep 692
06-25-2022, 11:41 AM | #38 | |
Rep 137
I don't know about the recalibration for tire changes. As mentioned earlier in the thread its due to regulations that speedometers display within a tight % of actual speed but in no circumstance should they display below actual speed. Its just the margin of error built in. I personally also hate this as I want to see exactly how fast I'm going and make my own decisions as far as whether I will exceed the speed limit and by how much. |
06-25-2022, 04:53 PM | #39 |
Rep 692
I posted the bimmercode changes required to adjust it (earlier in this thread). However they applied to F30 and prior. In G20 the entries are not present. I don't know if this is because bimmercode is not exposing them (in expert mode even) or if they simply are no longer available.
06-25-2022, 05:18 PM | #40 | |
Rep 15,858
Why change for wheel size? Tires are running similar rolling radius for all OE sizes. No need to recalibrate, comes within tolerance for speedo calibration from factory. BTW, an exact calibration is only accurate at the tread depth when calibrated, (along with a specific pressure), changes with wear anyway. So no speedo can be 100% accurate through a tire's life cycle. Always some sort of tolerance applying. |
06-25-2022, 06:43 PM | #41 | |
Professor
2250
Rep 1,813
Re:recalibrating for wheel/tire change, if deviating from the OEM sizes/widths the speedometer could be off. Been modifying cars for 30 years, and this has always been the case, I'm sure the Bimmers are no different. Regardless, it seems the +3 mph deviation is annoying to a lot of people. I've obviously got much to learn on this particular vehicle's quirks. |
06-27-2022, 08:13 AM | #42 |
Rep 552
This thread made me curious, so I compared a GPS speedo to my 2022 M340xi and the GPS MPH was just 1 MPH lower than the car's speedo at various speeds.
2022 M340xi Tanzanite Blue II Metallic
06-27-2022, 09:12 AM | #43 |
Rep 111
Just a thought.............
If I am running OEM 19" wheels with 225/40 R19 tires, the diameter of that tire is 26.1 inches. If I then keep the wheels, but mount tires that are 225/45 R19, then the new tire diameter is 27.0 inches. The increase in diameter is 0.9", or 3.4% larger. That would mean that if the speedometer was displaying 70 mph, the actual speed would be 72.4 mph. Two questions, please: - Would this higher sidewall aspect ratio (45%) allow the wheel to fit the car without physical interference? - If it does fit, would this tire change fix the indicated vs actual speed discrepancy for those who are experiencing it? Thanks................. Frank |
