04-25-2023, 11:06 AM | #1366 |
Rep 1,201
[QUOTE=SaltyPickle;30066035]If you read through the forum, it's not actually being neutered. The consensus is that the drivetrain may need to relearn/adapt after a software update. If you drive aggressively for a while, the pops and bangs will come back after every update.
CrownRoyal79284.00 |
04-25-2023, 01:00 PM | #1367 |
Rep 4,210
when i first got my car there was never a single burble or gunshot backfire. only the occasional pop once in a blue moon.
then someone said i need to drive it very hard. so i took it out and drove for an hour between 4000-redline wide open throttle as much as possible. then it magically turned into this symphony of burbles pops and gunshot backfires in sport plus, with gear stick in sport. unfortunately the car is too quiet to hear them all without all the windows down, removed all the boot floor boards, seats down. |
04-25-2023, 09:33 PM | #1371 |
Rep 693
04-26-2023, 07:12 AM | #1373 |
Rep 693
Blanked.
04-27-2023, 01:08 AM | #1374 |
Rep 48
I thought that the full Sprint mode was exclusive to the LCI (Idrive 8) vehicles, but discovered that my 2022 car has it: if I hold the left paddlе, the transmission downshifts a few gears and the display changes to the sport configuration with a "Sprint" label. I think this came with the 11/2022 software update. Before the update, the downshifts were there, but I do not remember seeing the Sprint label.
04-27-2023, 06:30 AM | #1375 | |
Rep 693
04-27-2023, 07:50 AM | #1376 |
Rep 361
I learned that I hate the windshield washer system. The stupid tubing sitting in channels is a PITA when wiping after washing the car. They keep popping out.
2018 MB E400 Coupe
2023 M340i X drive (Mineral White Metallic, Oyster Vernasca Leather, DAPP, Shadowline, PAP, Premium, Cooling & High Perf Tire, Adap M Susp, HK, Drive Recorder, Sensatec Dash) |
04-27-2023, 09:29 PM | #1377 |
Rep 1,201
Are there any customizations for sport HUD in ID8 LCI m340? Was wondering if you can see any type of tach with rpms or even a gear indicator. I went up some curvy roads the other day and noticed missing a gear indicator while the steering was cranked. With the short ratios of ZF8, it’s not always obvious what gear you’re in lol.
04-30-2023, 10:28 PM | #1378 |
Rep 233
Drives: BMW 330i M Sport
My gripe is not that, but that there is no 'drip sweep' after using the washers. On most modern cars, when you use the washers they do maybe three or four sweeps and then after a pause of around 20-30 seconds, a final sweep to catch any remaining drips. I always have to do that manually on the G20. First world issue for sure, but it has so many other handy little features that it strikes me is an odd oversight.
TNCatDaddy4.50 |
05-01-2023, 12:38 AM | #1379 | |
Rep 356
Obormot0.00 |
05-01-2023, 03:09 AM | #1380 |
Rep 233
TNCatDaddy4.50 |
05-02-2023, 01:31 AM | #1381 | |
Rep 302
2022 M340i xDrive, Mineral White/Tacora Red, Modesta Coated
05-02-2023, 08:57 AM | #1382 | |
Rep 1,799
I never remember to turn off the auto function after driving. My E90 always turns off the functionality after shutting down the car. |
05-02-2023, 08:33 PM | #1383 | |
Rep 233
05-04-2023, 01:57 AM | #1384 |
Rep 76
What I don't understand is it pushes the water in front of the wipers, the wipers push the water up beyond its reach and then it just drips back down and leaves a streak.
05-05-2023, 08:46 PM | #1385 |
Rep 82
So I just learned that I can roll the windows down using my key fob by holding down the unlock button. But, I can't close them remotely, even with the app. Is there a way to do this via bimmercode?
This is my first BMW. |
05-05-2023, 10:04 PM | #1386 |
Rep 182
Drives: 2023 M340xi Portimao Blue
If you hold the lock button on the keyfob it should close everything the same way.
