06-15-2020, 08:32 AM | #463 | ||||
Rep 512
I have not fanged mine a lot , just once and wow the power is fantastic But for normal driving it doodles along. I think I would like your car ..heheheh... in the future , I can just imagine what yours must feel like !! |
06-15-2020, 05:30 PM | #464 |
"It's so choice...I highly rec. picking one up"-FB
48
Rep 133
06-15-2020, 08:31 PM | #466 |
Rep 306
06-16-2020, 02:55 AM | #467 |
Rep 512
Thanks baturbo !! Drives like a dream..still trying to work out electronics.
Music is great with Apple Carplay and Tidal. I set the bass up about 3 notches , I think there was a youtube video which reviewed the Harmon Kardon system and gave the recommendations. It's not as good as the mark Levinson in the Lexus, but still very good. That Connect App on the Iphone is a bit of a scam, the info does not seem to be real time , I close the door but it says its open hahahha. Still have not got that 3d view to work. |
06-16-2020, 03:15 AM | #468 | |
Rep 512
Can't wait to take it on a looong drive up some swoopy mountains, in the Burbs I am really limited ,just toodling along at the speed of a Prius hhahaha. Also got those Brigestones run flats, don't have anything to compare against so all good for now. Now I know for sure, my next car will be a BMW 340ix or of course if I win lotto M3 7th Gen !! |
06-16-2020, 03:16 AM | #469 |
Rep 512
06-16-2020, 03:34 AM | #470 |
Rep 359
Hey, are you all you guys being respectful of the 2000km running in recommendation? I’m struggling to get the Ks up, especially since I like to use the electric motor to test range and charging characteristics.
06-16-2020, 05:08 AM | #471 | ||
Rep 512
And yes nowhere to go as well aaargh Going to Coles is just not going to cut it 😂 |
06-16-2020, 05:10 AM | #472 | |||||||
Rep 512
So quick question to all what pressure do you pump your tires ? Here is the sticker on the door Sorry wrong picture here is the correct one |
06-16-2020, 05:48 AM | #473 | |
Rep 359
But my sticker suggests 40 for my configuration. TPMS says 3 of the tyres are at 39 and one at 41. My gauge said all were 40. So I might have to check it again. Are yours lower? If so it’s probably because my car is over 200kg heavier (a bit like me after 3 months of covid) |
06-16-2020, 06:18 AM | #474 |
Rep 512
Ok lets try again
06-16-2020, 07:54 AM | #477 |
Rep 512
Thanks Slideit , now I am really confused.
Our cars are the same right , except yours is a Hybrid. So tyre sizes and tyre pressure should be the same ? How come the sticker is different. I looked at the UK site for tyre info and their sticker also has ECO Pro as a variable in the mix I can understand Steve's are different as he has a 340ix |
06-16-2020, 08:00 AM | #478 |
Rep 512
Hhaha, I discovered Individual Sports mode and the Plus setting
The standard config was set to Sport not Sport Plus, I changed it and now it makes a baby dog growl and pretend downshift noises hahaha. The steering on plus mode is much too heavy , so set it to comfort. I am quite annoyed I dont have TPMS , I know it was an option , but I thought it came with the msport package , obviously not. Can you check if you have it slideit, so if you don't it just gives you that your tyres are not flat.but it does not give you individual pressure readings. |
06-16-2020, 08:44 AM | #479 | |
Rep 512
06-16-2020, 04:47 PM | #481 | |
Rep 359
The one thing I'm not sue about is if all cars get the hardware, and it's just a software switch. Because as far as I know you can buy TPMS from the connected store. and I've read of people coding it in. |
06-16-2020, 07:13 PM | #482 | ||||
Rep 512
I did see on a Malaysian BMW web site to put in the TPMS monitors on the tyres after the fact costs like $600 as they remove all the wheels take off the tyres etc. So not to sure if the hardware is different if you select the $500 pre-ordered option or you omit it. Could not find anything on the connected drive store only the hard drive option. |
06-16-2020, 07:21 PM | #483 |
Rep 359
That's strange. I remember I got into a discussion with the dealer (and on here I believe) on if it's better to option it with the build or add later. It worked out that the cost was the same, so I just optioned it.
06-16-2020, 07:22 PM | #484 | ||
Rep 512
