12-14-2023, 12:48 AM | #1453 |
Rep 200
toddwalton - while I can understand the recommended pressure change with temp change while driving, I have no clue why recommended pressure should change with outside temperature changes. The only reason I can think of is that BMW does not want people to worry too much and adjust the pressure too often, so that is why they change recommendation in iDrive with temp change. So if you have setup in to rec. in 20°C your car will show your pressure on point in 39°C as well. Not sure this is correct way to address this topic though.
As for the difference in recommended tyre pressures - I am on non-RFT as well and even if there was need for different pressure from non-RFT to RFT it should be stated on the jamb, don't you think? Our vehicles can be fitted from factory with either type of tyres. Vehicle weight is plausible reason, but as G26 is heavier(or same weight?) than G21 the pressure for G26 should be higher in my mind? |
toddwalton1306.00 |
01-04-2024, 05:25 PM | #1454 |
Rep 101
I learned recently that on my MY 24 M340Xi, 1) if you ask the personal assistant to navigate to a destination while you’re backing up the car slams on brakes and tells you not to do that, and 2) if you are backing out of a one car garage and have the active PDC emergency braking on, many times the sensors pick up the sides of the wall and slam on brakes.
So unfortunately I have just turned the emergency braking off. |
dancing__narwhal141.50 |
01-04-2024, 06:27 PM | #1455 | |
Rep 747
01-05-2024, 02:25 PM | #1456 | |
Rep 52
01-05-2024, 02:28 PM | #1457 | |
Rep 52
toddwalton1306.00 |
01-05-2024, 03:07 PM | #1458 |
Rep 101
Same here two car but separate doors. Even with the PDC emergency braking off it still buzzes at me unless I go real slow like you said.
01-06-2024, 09:03 AM | #1459 |
Rep 1,635
Happy to help. The new BMW climate control system is a dream, set it up as shown and and it will behave just like the climate control system in your house- full blast to get you to maximum cooling/warming and then fan speed slowed way down to a low level as it maintains itself. Set this up once this way, and from then forward 90% of the time you'll never have to touch it. If you need a bit of an adjustment, all you have to to is tap the temperature control +/- 1 or 2 degrees either way to tweak it. |
01-12-2024, 05:15 AM | #1460 |
Rep 379
The same also happens when I back out from a steep driveway and the rear sensors detect the road as a vertical wall and slams on the brakes.
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK 2012 F30 328i Sportline (Mineral Grey) |
01-12-2024, 05:20 AM | #1461 |
Rep 379
After completing a 2000km road trip over a week, I noticed that the clock does not change as it crosses to a new time zone, despite it being set to Automatic. ☹️
BMWphile
01-15-2024, 03:35 PM | #1464 |
Rep 2
Drives: BMW 330e (2023, iDrive 8)
I have my car since last Friday and while I love it so far I am starting to discover how many advanced functions are unavailable in my region, even though I am based in the EU.
Just in the last few days I have found out that: - no Digital Key (Plus), this one is on Samsung insisting on using its Wallet - no garage door remote control on the mirror - no Spotify - no traffic lights recognition in the Assisted Driving And probably many more I have not found as of yet. It doesnt detract that much from this great car but still I think it is a bit unfair. |
01-16-2024, 12:44 AM | #1465 |
Rep 200
fortuneman - yeah, Samsung's is the worst company I have seen in regards to (mobile phone) software! Not having the option to use DK because of that sucks big way! I am really pissed off of them. Traffic lights recognition could be due to regulations. My car behave differently in different regions - in my home country it doesn't read any signs other than speed limit. In Greece it reads many more traffic signs - e.g. "overtaking forbidden", warning signs etc.
01-16-2024, 01:54 AM | #1466 | |
Rep 66
Don't get me wrong I use the auto setting and find it quite good but I do frequently still make minor adjustments to the temperature and fan speed. |
01-16-2024, 07:56 AM | #1467 | |
Rep 1,635
Modern cars are built to have the AC on at all times, summer and winter, they shouldn't even have the option to turn the compressor off. |
01-16-2024, 08:55 AM | #1468 |
Rep 38
Drives: 2024 BMW M340i
I have a 2024 M340i and it always annoyed me when switching driving modes to have the control display flash "Sport" or "Comfort". Found out turning off popups for Driver Experience stopped this from happening. Much better!
zlatko117.50 |
01-16-2024, 09:01 AM | #1469 | |
Rep 39
toddwalton1306.00 |
01-16-2024, 10:41 AM | #1470 | |
Rep 692
01-16-2024, 04:25 PM | #1471 | |
Rep 187
-Spotify is connected to Connected Drive account, if you use German Connected Drive account, you will have Spotify (I am using German Connected Drive in Slovenia). -Traffic lights are region based. They work in Europe, but they need to be coded. They are not working good. In my home country some traffic lights are accepted automaticaly, so my car stops at red light, on same of them i need to press SET button, some of them are not even recognized. |
zlatko117.50 |
01-17-2024, 04:00 PM | #1473 | |
Rep 2
So if I change the Localisation info from Slovakia to Germany, Spotify will simply magically appear? Double-checking, because in order to change it, the MyBMW app tells me I need to remove my car from my BMW ID, which means setting it up again Is this the only reason you picked the German version, or just Spotify? |
01-18-2024, 09:25 PM | #1474 | |
Rep 66
I'll continue risking my life turning the AC off. s/ |
