09-29-2022, 09:56 AM | #45 |
Rep 380
In BimmerLink the Sensorvalue "Damper setpoint" and Actual damper values can be monitored. I watched both change between 10 and 73.5 degrees while standing still and switching between comfort and sport (M440 with option 2VF).
This could be something to check for you that doesn't notice a difference. |
gnolivos319.00 |
09-29-2022, 08:33 PM | #46 | |
Rep 692
09-29-2022, 09:00 PM | #47 | |
Rep 692
My car has S2VF. M adaptive Suspension. Seems like bad news. Should I bring this up with the dealer. Car has 8500 miles. I've always suspected the dampening is not doing anything and car seems always tight and rough.
09-29-2022, 09:30 PM | #48 |
Rep 692
Also I see errors in the relevant module:
10-03-2022, 02:26 PM | #49 | |
Rep 137
I'd be interested in what your dealer says. I too have not felt a difference between sport and comfort but have no quantifiable way to show this to them. |
gnolivos319.00 |
10-03-2022, 03:08 PM | #50 | ||
Rep 692
10-05-2022, 02:03 PM | #53 |
Rep 692
Do you have adaptive M suspension? It's an option an quite a rare one from what I've gathered.
10-05-2022, 06:09 PM | #56 | |
Rep 601
Was told it can’t be done. Hardware on the G20 won’t work with a sport plus setting. Disappointed, since sport suspension is good, but wanted an even stiffer version. You know something we don’t know yet? |
10-05-2022, 08:39 PM | #57 |
Rep 4,143
no, no luck.
but i do want to code comfort individual. i turned on comfort individual on the expert mode and now the comfort button cycles through 3 programs - comfort, comfort plus, and blank i i'd like to code comfort individual somehow! when you guys press the comfort button, does it cycle through a blank program on the instrument cluster (where it says comfort, sport, etc) |
10-06-2022, 03:20 AM | #58 | |
Rep 193
But if you ever figure this out please share. I'm desperate for a comfort individual coding!
Current car: G20 M340i Black Sapphire (Stage 2 BM3 and xHP with Downpipe)
Previous cars: 2019 VW Arteon (Stage 1+), 2017 Audi TTS, 2015 Audi S3 Sportback, 2006 BMW 335i Coupe |
10-17-2022, 09:33 PM | #59 |
Rep 1
This is on my 2023 Lci
Has come up 2 in 3 wks of ownership
Have now idea how this happened. Has anyone come across this Screen with out coding ecm Thanks |
10-29-2022, 06:31 AM | #60 |
B58 Power
492
Rep 628
Has someone already tried the Alpina Flash for the real Comfort Plus?
I know the process but two parts are missing. What Typeschlussel do i need to choose for an G21 PreLCI build in 05.2022? What is the correct ECU to flash? This coding is only done in the BDC and MGU but there should be a dedicated ECU for the adaptive suspension.
10-30-2022, 06:52 PM | #61 |
Rep 2
worked in 2022 G20 330i
Greetings from Australia,
Thank you so much guys for your advise. I can also confirm the coding worked in 2022 G20 330i. I used bimmercode with OBDLink CX but had to search for the coding name in the expert mode. Took some time to figure them out but all worked. Once again thanks. |
09-08-2023, 02:26 AM | #62 | |
Rep 62
Just what @g21 mentioned: sport- heavy steering, stiffer suspension comfort - lighter steering, STIFF suspension comfort plus - even lighter steering, bouncy suspension
G20 330i M-Sport | Portimao Blue | Adaptive M | M-Sport Brakes |
Retired: F30 328i M-Sport | Estoril Blue | Adaptive M | M-Sport Brakes | Bootmod 3 | K&N Filter | Remus Exhaust | Rockford P300 Sub | E90 320i LCI | Black | E90 323i M-Sport | Titanium Silver | Formula 1 Tint | Evolve Technik ECU Tune | K&N Filter | Remus Powersound | Focal K2 Power 100KRS | Alpine 12" SWS-1223D | Alpine MRX-M50 | Last edited by SilverZeus; 09-08-2023 at 07:05 PM.. |
