Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Is it okay to upgrade my leased car to the HK sound system?
      08-10-2020, 10:26 AM   #1
bacchus7
Drives: 330i xDrive MSport
Hi all. Saw a handful of similar threads about this, but not an exact answer.
I'm getting a great deal on an almost loaded 330i. The one thing it's missing is HK sound. Unfortunately, It was not possible to find a deal on a 2020 330i with similar specs in the color I like (black). My lease broker told me its not a problem to upgrade the the audio system, and he says BMW won't mind since it enhances the car and it doesn't violate anything on the lease. Is that correct? Does anyone strongly advise against it? I see all the 'plug & play' options and figure why not, at the very least, swap the speakers?
Anyone love the base Hi-Fi system?
      08-10-2020, 10:34 AM   #2
FrostNixon
Drives: vw golf
I have the hifi system because it's more than enough for me. However, from what I understand, once the vehicle has been manufactured you can't upgrade to HK because some things don't match and you can't put the buffer. There are some topics on that.
      08-10-2020, 11:04 AM   #3
VipinLJ
VipinLJ's Avatar
The HiFi system isn't that bad once it's broken in. I have/had B&O in my Audis and while it doesn't compare, the HiFi isn't as bad as the base system in Audis. Only problem is, to get some clarity, you'll need to play music loud. That can be a problem when there are other people in the car.
Upgrading speakers to bavsound/eaton apparently solve that problem even though loudness remains the same.
I've listened to the HK and while it's nice and I would prefer that (isn't as good as the B&O in similar Audis), I don't regret not getting it.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      08-10-2020, 02:09 PM   #4
del82
Drives: BMW M340i xdrive
You can't upgrade to HK and maintain full warranty because BMW do not have an official retro fit.
You can buy all the parts (cost a few $€£) but BMW won't install it.
Your broker is telling fibs.
You could replace the speakers. BMW will never know unless something goes wrong.
Current: 2020 M340i
Past: M140i, Z4 35is
      08-10-2020, 05:23 PM   #5
greekcs
greekcs's Avatar
Drives: 2020 M340i xDrive
I wouldn't go through the hassle. If I were to purchase the car at the end of lease then I would consider this.
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
      08-10-2020, 05:36 PM   #6
VipinLJ
VipinLJ's Avatar
I agree 100pc
      08-10-2020, 10:55 PM   #7
bacchus7
Appreciate all the replies, real helpful.
Guess I'll wait to see how the hifi sounds to me - i love my music, not enough to go crazy with new subs and the whole 9 though. The bavsound speaker upgrade is really intriguing though. HK isn't an option as noted, but going to see how I like the hifi before putting any order in. After reading a bunch around I'm not too worried about the lease situation with upgraded speakers if it's plug and play - we shall see!
      08-10-2020, 11:28 PM   #8
Kaps335i
Drives: 2013 335i xDrive
I have the HK, and it is a bit disappointing.
2020 M340i xDrive
Dravit Grey Metallic
Modifications
July 23rd - Dyno Tune
      08-12-2020, 12:26 AM   #9
Xsapper
Xsapper's Avatar
233
Drives: G20 330i M Sport
I updated the base Hifi on my last car (F30), all plug & play and removed it all before handing it back. I doubt if the dealer ever knew.
      08-12-2020, 01:29 AM   #10
VipinLJ
VipinLJ's Avatar
The dealer won’t know if you’ve swapped speakers or not unless they actually look for it. It’s more about the hassle of doing it than the dealer finding out. I watched a few videos on upgrading the speakers/woofer in the G20 and it seems like a headache, especially on a leased car.
      08-17-2020, 06:04 PM   #11
rickkap
Drives: 320d XDrive M Sport (G20)
HK system isn't great ... i wouldn't bother i can fart louder than the bass unit under the seats
      08-22-2020, 10:45 AM   #12
Kleev
Drives: BMW M340i xDrive
Interesting. I have B&O in my last Audi and I think HK in my new BMW is better.
      08-31-2020, 09:15 AM   #13
Calamari
Drives: 2024 G21 330d, 2008 E87 118i
For HiFi system there is a simple solution to get much better sound. If you don't want to replace speakers - you can start with upgrading HiFi system with a plug-and-play amp - MatchUp 7DSP.
It's a 15 minute job, but it's a bit pricey. However, it will significantly improve the sound of the HiFi system as the amp has a DSP which has sound profiles specifically designed to bring the best from OEM HiFi speakers without overpowering them.
Once your lease is out, you can return OEM HiFI amp back in 15 minutes.
The amp can be put in your next BMW since it's compatible with all BMWs with HiFi system. The amp also works with other german cars with certain audio systems, like Mercedes. You just buy a car-specific harness, and load the DSP setup file for that vehichle.
See this thread for much more detail: https://g20.bimmerpost.com/forums/sh....php?t=1737016
      08-31-2020, 02:23 PM   #14
FrostNixon
Drives: vw golf
I wonder how much good it will do, seeing as it's almost the price difference between HiFi and HK.
      08-31-2020, 04:08 PM   #15
Calamari
It's a fair question. The thing is, to get way better sound than HK you need to do the whole thing, replace the speakers (at least all mids and tweeters) and upgrade the AMP. That combination is much bettee than HK.
It all comes down to how much you plan to invest, and how important good sound is to you. That is something that everyone needs to answer for themselves.
MatchUp AMP is a great start. It's specifically designed for OEM HiFi speakers and packs 1300 Watts of power. It will bring the oem speakers to life, without a doubt. Essential advantage of the MatchUp amp is the DSP in it that allows you to get almost perfect sound stage by adjusting the timing/delay of all audio channels.
I am currently running MatchUp amp with all ETON mids and tweeters on center, front and rear channels and the results are very very good. Way better than HK. And I haven't even replaced the woofers (yet).
      09-01-2020, 10:11 AM   #16
FrostNixon
Drives: vw golf
I am currently running MatchUp amp wotj all ETON mids and tweeters on center, front and rear channels and the results are very very good. Way better than HK. And I havent even replaced the woofers (yet).
Yeah you can do great stuff I agree, my main question always is - how long do you spend in your car and how much of an audiophile are you to go through all that, for me the hifi is plenty and I have a great setup at home where I listen to music, music in the car is just to have something other than tire noise, and to be honest with bluetooth I've been listening to more audiobooks and podcasts lately rather than music.
      09-01-2020, 03:10 PM   #17
LarrySinNJ
LarrySinNJ's Avatar
Drives: 2019 330i xDrive
I had the B&O on my 6er, and had I leased new, I would have been pretty mad spending > $3,000 for something only slightly better than the HK in my G20 (not counting the cool motorized front center speaker...).
2019 G20 330i xDrive Med. Blue/Cognac Leather ZCV|ZPP|ZPX|HK|Remote Start (Ret'd)
2016 F06 640i xDrive Med. Blue/Red Leather MSport|B&O|Driver Asst+|Cold|Night (Ret'd)
2013 F30 335i xDrive Mineral Grey/Black Leather (Ret'd)
2011 E90 328i xDrive Space Grey/Black Leather(Ret'd)
2009 E90 328i xDrive Monaco Blue/(Ret'd) 2007 E90 328i xDrive Graphite (Ret'd)
      09-01-2020, 05:23 PM   #18
Calamari
I agree. I live in a building where I cannot listen to loud music and I do a lot of long distance driving so the car is the place where I can really enjoy music. If the situation was different, I wouldn't bother upgrading Hifi. I would probably just replace front and center speakers to get less muddy and more natural mids and highs, and that's it.
