02-04-2023, 02:32 PM | #1 |
Rep 692
BEST G20 Coding Options found here
Just wanted to share my "curated" list of applied and verified/tested Coding options for my G20. I have had these running on my M340i for 14 months without issues.
STANDARD CODING: ================ -5 blinks turn signal. Standard coding -Window lifter interruption when door opens, set to OFF. Standard Coding. -Hazard Braking, set to Active. Standard Coding. -Auto mirror tilt angle, from 70 to 50 deg. Standard Coding. -Initial Seatbelt reminder, set to OFF. Standard Coding. -Seat Heating Cooling setting memory set from 15 mins to 24 hrs. Standard Coding. -Refresh Rate Digital Speed from 2fps to 5 fps. Standard Coding. -Brake Force Display Activation speed from 5km/h to 40km/h. Standard Coding. -Set ADAPTIVE as default driving mode. Standard Coding. EXPERT MODE CODING: =================== -Brakeforce blink tail lights. GEFAHRENBREMSLICHT_TYP from NICHT_AKTIV to BREMSLICHT_BLINKEND -Disable legal disclaimer camera MACRO_CAM_LEGALDISCLAIMER from ID_MIT_TIMEOUT to KEIN_ID -Close Moonroof when it rains: HU ECU: HU_MGU_REGEN_SCHKIESSEN from inaktiv to AKTIV then in Moonroof ECU: REGENAKTIV from inaktiv to AKTIV REGENAKTIV_ROBUST from inaktiv to AKTIV STATUSRCTIME to DEFAULTWERT REGENPOSITION to GESCHLOSSEN -Enable Exhaust Flap position configuration (open up Engine Sound in options menu in idrive) in HU ECU: Display_Configurability_Engine_sound from inaktiv to AKTIV Display_Menu_Configuration_Sound from inaktiv to AKTIV -Enable B&W audio (in HU ECU): AUDIO_SYSTEM from alev3_ram to ALEV4_RAM -Enable Cornering lights ALSO if high beams are on (FEM module?) C_CLC_HIGHBEAM_DIS from disable (0x01) to ENABLE (0x00) 'note, I think these tags are backwards to avoid confusion in the interface? 0x00 is usually enable -Disabled legal Disclaimers at startup. Prefer to do this in expert mode. In HU ECU: LEGAL_DISCLAIMER_TIME from Ld_mit_timeout to KEIN_LD -Enabled Speed limit info cushion. Gives me plus minus 5 cushion and configurable in iDrive even. This has to be changed in HU and also in BDC. 4 changes total VOFFSET from nicht_aktiv to GEN_2 (0x02) VOFFSET_LANGSAM from nicht_aktiv to GEN_2 (0x02) -Tweaked again cornering lights to trigger upon turn signal at even higher speeds C_CLC_BLINK_V0 from0x30 to 0x40 (40 hex is 64 kmh dec, equals 40mph) C_CLC_BLINK_V1 from0x38 to 0x48 (48 hex is 72 kmh dec, equals 45mph) -Enabled tow hitch camera view in HU MACRO_TAILER_COUPLING from inaktiv to AKTIV -Fix for dimming with tinted windows: Headunit - 3005 APIX_CID_UND_ZIN - DIM_CURVE_X2 – change values to 0x00, 0x00 (from 0x1F, 0xC0) Instrument cluster - 3000 Anzeige_Konfiguration – DIM_TAG_NACHT_LICHT_EIN_ENABLE – change value to aktiv Instrument cluster - 3005 FuBi_Parameter – DIM_DTN – change value to 0x5F (from 0x3F) seems better compromise for SOME dimming during dusk than 0x7F that forums said |
10
gaushell7.00 B58josue15.00 okankaymak3.00 BayM34072.00 jd85_m0.00 eagerbimmer6.00 Frank_Zuccarini46.50 Eljefe2594.50 apwm340i64.50 Das_Stiggy45.00 |
02-06-2023, 03:12 PM | #3 |
Rep 692
Wrong thread honestly.
02-06-2023, 03:13 PM | #4 |
Rep 692
Also, you can keep standard Hud in sports mode without coding. Check your settings in the iDrive
02-19-2023, 04:57 PM | #5 |
Rep 16
Drives: 2021 Bmw 330i G20
What app/apps you were using?
02-20-2023, 02:32 AM | #7 |
Rep 2,047
You can use esys(with launcher or bimmerutility) ,bimmercode ,protool
https://g20.bimmerpost.com/forums/sh....php?t=1673049 |
02-20-2023, 02:07 PM | #8 | |
Rep 111
Thanks...................... Frank |
gnolivos319.00 |
09-08-2023, 11:38 PM | #9 | |
Rep 7
gnolivos319.00 |
09-09-2023, 06:04 AM | #10 |
Rep 692
Yes it will fix the dark cluster issue
g20rafo1.50 |
01-11-2024, 09:23 PM | #11 | |
Rep 5
I just picked up a 2020 X3. The blinker sounds like it’s on steroids. Do you know if there is anywhere to change the volume? I found “Blinker_Volume” in one of the advanced/expert options. But oddly enough, that wasn’t it.
I apologize if this is not the right thread for this question. To be honest, rarely ever use forums. Any/all help to eliminate the loud late 1970s blinker volume is appreciated Cheers. Quote:
