Technical Topics DIYs and Coding Discussions Rain Sensing Closing of Sunroof
      11-30-2020, 09:58 AM   #1
larrylam646
larrylam646's Avatar
Drives: 2020 M340i xDrive
Sharing with G20 members....
Found this Thread on the G05 forum and coded to see if it worked - https://g05.bimmerpost.com/forums/sh...v#post26779217
I can confirm the "close to tilt position after 6hr" appears to work. Too cold to test the "close to tilt when it rains".
Specific FDL Coding:
FZD2 1D93 Regenaktiv aktiv
FZD2 1D93 Regenaktiv_robust aktiv
FZD2 1D93 StatusRCTime Defaultwert
HU_MGU REGEN_SCHLIESSEN aktiv
FDL Coding to close rather than tilt the sunroof - https://g20.bimmerpost.com/forums/sh...9&postcount=11
2020 Black Sapphire M340iX
Last edited by larrylam646; 10-26-2021 at 08:59 AM.. Reason: Added reference to FDL Coding to close rather than tilt sunroof
      01-06-2021, 11:47 AM   #2
Pdec08
Drives: BMW 330i G20
Where did you find:
I can find regen_schliessen and have it activated but the box is grayed out. Trying to find these other 3 items to activate. Thank you.
      01-06-2021, 06:59 PM   #3
larrylam646
Originally Posted by Pdec08 View Post
Where did you find:
The first three parameters are in the FZD2 ECU...
      01-07-2021, 01:44 AM   #4
Freelancer withour work
Freelancer withour work's Avatar
South Korea
9
Drives: BMW G20 320i M Sport
south korea is default
2014 ~ 2017 Chevrolet Cruze J300 1.8
2017 ~ 2019 Mercedes Benz W205 C200
2019 ~ 2020 KIA Motors YG K7 Premier 3.0
2020 ~ BMW G20 320i
      07-29-2021, 10:13 AM   #5
Bugy06
Turkey
Drives: 2017 MODEL BMW 3.18i ED
Hi guys. how can i encode these two items with BİMMERCODE? Can you rob your place? this item is grayed out on my vehicle
      01-04-2022, 03:16 PM   #6
gnolivos
Drives: Various BMW
I’m not sure whether the entire coding can be done with BimmerCode. I’d like to know if possible too.
      01-08-2022, 11:35 PM   #7
Bambazonke
Bambazonke's Avatar
Drives: 2017 X5 & 2020 X5
  [0.00]
Originally Posted by gnolivos View Post
I'm not sure whether the entire coding can be done with BimmerCode. I'd like to know if possible too.
Yes it can be done both ECU's have to be coded in expert mode very easy and quicker than using ESys Launcher Pro 3.7 which I also have. When in expert mode just type in "regen" in the search function and it will automatically find the FDL parameters you need to change as outlined in the OP post above.
I changed mine to close fully and extended the time from 6 hrs to 8 as my X5 sits in the hot Queensland sun from 8 till 4 in the afternoon much like living in Florida. Really wish I could also enable my windows to do the same like I did in my 2008 VW Tiguan using VCDS software from Ross Tech
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
gnolivos319.00
      01-12-2022, 01:04 PM   #8
gnolivos
Drives: Various BMW
Hey which ECU is FZD2?
https://g20.bimmerpost.com/forums/sh...5#post29807925
      01-12-2022, 02:58 PM   #9
Bambazonke
Bambazonke's Avatar
  [0.00]
In BC look in Roof Function Centre
gnolivos319.00
      01-12-2022, 02:59 PM   #10
gnolivos
Drives: Various BMW
Found it thanks and coded everything. Will test sometime.
      01-12-2022, 03:48 PM   #11
Bambazonke
Bambazonke's Avatar
  [0.00]
Lock the car & wait 10 mins before spraying water on windscreen sensor
gnolivos319.00
      01-12-2022, 03:49 PM   #12
gnolivos
Drives: Various BMW
Didn't even consider it would work after engine was off and car locked. If that's the case even better.
      01-22-2022, 01:16 PM   #13
Daveljones
Drives: BMW 330d
Thanks for sharing. I'm very new to both bmw and bimmercode but have looked to get this programmed for my 2020 g20 but can't finfld anything going in to expert mode and searching for regen.
I don't suppose you could tell me step by step (like I'm a 5 year old &#129315 please? I'd like it to fully close if it rains. Thank you in advance for any help.
      02-04-2022, 11:14 PM   #14
azlan96
Malaysia
16
Drives: G28 330Li
Is there any way to code for the sunroof to fully close when it detects rain and not tilt?
      02-04-2022, 11:49 PM   #15
Bambazonke
Bambazonke's Avatar
  [0.00]
Yes read the first post of this thread. The OP has added a link to another post which highlights what to code for the sunroof to close fully instead of to the tilt position
      02-05-2022, 10:11 AM   #16
gnolivos
Drives: Various BMW
Keep in mind that after this coding, you will need to go into iDrive settings and enable the option. It will appear under general settings and I only just realized this yesterday!
      02-05-2022, 01:04 PM   #17
howiegu
Member
howiegu's Avatar
Drives: 22%E2%80%99 M440
Is there a way to change the time for the roof to close? The default is 6 hours.
      02-05-2022, 04:45 PM   #18
Bambazonke
Bambazonke's Avatar
  [0.00]
Yes it can be changed in the below FDL just bear in mind the value is set in hex code
gnolivos319.00
      02-05-2022, 05:06 PM   #19
Bambazonke
Bambazonke's Avatar
  [0.00]
After connecting the car in BC and have green dots next to each ECU. Look for the Roof Function Centre (FZD2 ECU) Click on the ECU. Then look for expert mode tab click on that, then do a search for "Regen" BC will then find all the relevant FDL lines in that ECU with regen in it and then change the values as per the OP's post once this done remember to press code command and follow the instructions on the screen. You will have to repeat the exercise with the Body Domain Controller (HU_MGU ECU) where there is only one parameter (FDL code) to change
      02-18-2022, 11:46 PM   #20
CyclingBroStyle
CyclingBroStyle's Avatar
FDL Coding to close rather than tilt the sunroof - https://g20.bimmerpost.com/forums/sh...8;postcount=11
Can this be done in bimmer code if so how and which modules ? I looked and can't seem to find is. Any help appreciated.
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey
BMW CCA #522637 use me as a referral for BMW CCA
      02-19-2022, 04:42 AM   #21
larrylam646
I do not used Bimmercode. Perhaps other members can help.
      02-19-2022, 07:10 AM   #22
gnolivos
Drives: Various BMW
Close Moonroof when it rains:
HU ECU:
HU_MGU_REGEN_SCHKIESSEN from inaktiv to AKTIV
then in Moonroof ECU:
REGENAKTIV from inaktiv to AKTIV
REGENAKTIV_ROBUST from inaktiv to AKTIV
STATUSRCTIME to DEFAULTWERT
REGENPOSITION to GESCHLOSSEN
Note: a new option will then appear in iDrive to close moonroof when it rains. Must check box to enable.
