11-23-2020, 02:06 PM | #133 | ||
Old Member
65
Rep 196
Drives: M340i, Mineral White
12-03-2020, 02:13 PM | #134 |
Rep 558
For those getting AA to work, may I ask what phone are you using?
I know only Google/Samsung phone with Android 10 or other brands with Android 11 would work wirelessly. But my non-Google/Samsung phone doesn't have Android 11 yet...would AA work via wired connection? |
12-03-2020, 02:21 PM | #135 | |
Rep 156
12-03-2020, 02:29 PM | #136 |
Rep 558
12-03-2020, 02:31 PM | #137 | |
めらみぽっぷ fan
376
Rep 345
You can find info on the Developer mode workaround here: https://www.xda-developers.com/wirel...android-phone/ https://g20.bimmerpost.com/forums/sh...&postcount=119 https://jrklein.com/2019/04/06/using...k-ios-android/
12-03-2020, 03:13 PM | #138 | |
Rep 558
12-15-2020, 03:21 PM | #139 |
Rep 1
I have a OnePlus 7T and it works just fine over wireless. My phone is not on "the list".
Now if I could just figure out how to make things full screen or at least take up more of the screen. They take up a quarter of the screen with a black bar with date and time. Is this just the way it is or am I missing something? |
02-16-2021, 04:31 AM | #140 | |
Rep 8
Just coming back here to report that AA started working yesterday. Nothing I tried before worked until suddenly I got a message on my phone (still the Galaxy A7 with Android 10) saying it detected my car supported AA and if I wanted to update to use it. After accepting all the confirmations and manually updating the basic Google app (it got stuck in the automated process) it is now working. Just drove to work this morning with Google Maps whilst listnening to a downloaded podcast on Podbean, all in AA. |
02-17-2022, 02:36 PM | #141 |
Rep 8
Hello!
I was just provided a brand new BMW 320d xDrive as a company car and I am having trouble finding/accessing android auto. Build would be late 2021/early 2022. I am not sure if the car has it or not but I was under the assumption that they all have this feature now. When I check the apps section of the car, there is no option for android auto even after connecting my phone via bluetooth. May I please have some assistance from some other users on how to identify if the car should have android auto or not? Thank you! |
02-17-2022, 05:53 PM | #142 |
Rep 222
What phone do you have? If you have a quick Google search you'll see that Wireless Android Auto is limited to only certain phones / OS versions.
Otherwise (from memory), if you go to devices, you will need to connect to bluetooth, then wireless, then Android Auto. If none of this makes sense, can you let us know what version of iDrive you are running - maybe you're on iDrive 6??!?!?! But I don't think that's the issue for a late 2021 build, it's likely you don't have a compatible phone... or it's something to do with chip shortages?!?! |
02-17-2022, 07:32 PM | #143 | |
めらみぽっぷ fan
376
Rep 345
You need to connect via Bluetooth and Wi-Fi Direct. Bluetooth is used for pairing and Wi-Fi Direct for data transfer. Your phone's network data plan is used for internet. You may need to do both of these: 1. Have mobile data set to always on or 'Switch to mobile data' enabled (preferred). If it still doesn't work: 2. Connect to the car via Wi-Fi Direct and view the IP address (Advanced). Take a screenshot or write it down. Now go to the regular Wi-Fi settings page. Go to the advanced options for the same network and modify the settings. Change from DHCP to Static and enter the IP address from before.
02-18-2022, 02:00 PM | #144 | |
Rep 2,249
02-18-2022, 03:44 PM | #145 | |
Rep 8
I'm using a Pixel 6 phone so it should be fine. I can connect the phone to the car via Bluetooth but I still don't see an option for Android auto. The mybmw app on the phone comes up with a little notification to connect via WiFi but the option just isn't there in the cars settings |
02-18-2022, 03:47 PM | #146 | |
Rep 8
I would agree here, the car is a brand new build so I would imagine it's supposed to be there. My phone is all up to date so no issues on that side. My phone comes up with the searching for Android auto notification for a moment after connecting via Bluetooth, then the mybmw notification pops up to say to make sure WiFi is turned on in the car and the phone. WiFi is on phone but I don't see an open in the cars settings I can connect to Bluetooth fine but there is no additional option in the cars connectivity settings that shows a WiFi connection. Is it possible the car does not have WiFi at all? |
02-18-2022, 03:49 PM | #147 |
Rep 8
02-18-2022, 08:08 PM | #148 |
Rep 222
The issue is definitely that you are not connected to wifi. In your device connections in the car menu it should be there. Do a quick google search on how to connect to the wifi on iDrive 7. This is definitely an issue... hopefully the issue.
Edit... check this video out. Once you have WiFi connected - you will need to find the connection on your phone and add the password etc. Then on that same screen he has for devices (25 seconds into the video), click on your phone and then scroll down to Android Auto and connect. |
02-18-2022, 11:13 PM | #149 | |
めらみぽっぷ fan
376
Rep 345
Now, assuming the above requirements are met... When you go to the Apps menu, there should be 4 items listed: Installed apps, Carplay, AA, and BMW Store. If you don't see AA there, press the Option button under the iDrive controller. Then "Update apps and services" and let it finish. It may take some time after this for the apps to finish downloading and installing (via the car's built-in LTE connection). I'm not sure if it only downloads while the car is on or not. I'm pretty sure it only showed up in my car after I left it parked, but it may have downloaded while driving and required a restart to show up. Go for a drive and/or leave it parked in an area with good reception. Finally, you should be able to tap Android Auto under the Apps menu or Mobile devices to initiate pairing. You can check your options list with a site like https://bimmer.work/.
02-19-2022, 04:31 AM | #150 |
Rep 8
Hi All,
i just spoke with BMW customer support and they have informed me that there is currently a chip issue and that a software update will come sometime in 2022 what will resolve the issue. They explained that this is why android auto and apple carplay is not currently functional in the car but will show up once the update is released. I suppose I wait until the software update is sent out. Thank you for your support! |
02-19-2022, 09:07 AM | #151 |
Rep 384
KoolMoeDee, how do you interpret that explanation? Did BMW change the type of HW in your car to other types that is not compatible with the existing SW, so that it can be fixed with a SW update?
(Chip issues has so far meant that HW is missing in the delivered car ...) |
02-19-2022, 01:31 PM | #152 | |
Rep 2,249
TL;DR. The headunits used in the new builds have a different Wi-Fi chipset, and the drivers ( software ) weren't ready in time . So , the 6P1 hides the functionality , and a remote software update to a 22-03-5xx istep Will bring it back ( along with some enabling codes ) |
02-20-2022, 01:40 AM | #153 | |
Rep 8
New BMWs or at least certain new models have a new chip in them in which there are currently software issues, system bugs or compatibility problems which will be resolved with a software update in the future. Untill then, the features tied to this chip are removed. |
02-20-2022, 01:42 AM | #154 | |
Rep 8
