04-09-2024, 05:15 PM | #1 |
Rep 694
NEWS app not working
My News app stopped working. This is a standard BMW connected service app.
It doesn't load the icon set in the list and also doesn't play the podcasts. Also my car is now requiring me to login every time I start the car. Lastly, my Spotify album art won't load. I've done reset, double reset, deleted account and re-added. Nothing fixes this. Any ideas? Tech support hasn't helped after 1 week back and forth.
04-09-2024, 08:59 PM | #2 | |
Rep 171
Once you have your driver profile, make sure you set up your driver profile recognition - have the car recognize your driver profile via the KEY and also set up a 4 digit pin code, the latter enabling the use of "Valet Parking Mode". Assuming all goes well, the car should greet you and your setting will automatically adjust when entering the vehicle with the key you used to set up your profile! Doing all of this should make the "enter credentials" notification go away indefinitely. lol NOTE: I only drive and use my car using the physical key and the only thing I use the app for is remote start. That said, I've noticed that those using the Digital Key have to manual select their driver profile, whereas those who use their physical key will have their driver profile loaded automatically. As for the "News" App, to be honest, your the first and only person I've come across that uses the News app in iDrive - nothing wrong or bad with that! I believe there is a Software Update available for iDrive 7 - this can be found in "General Settings" --> "Remote Software Upgrade" --> Follow the instructions. If your vehicle has an update, I would update the system and see if the problem fixes itself. Maybe the app is not working as they are making some upgrades/changes to it? Not trying to downplay it or make excuses, but just wanted to throw that out there. If all else fails, you could try taking your car in or calling the genius hotline number, but if it were me? I'd just download a news app to my phone and just listen to it via Apple CarPlay/Android Auto ALTERNATIVES/NOTE: Both Apple CarPlay and Android Auto have their own Spotify app that comes straight from your phone - I mention this as an alternative - the same applies for Sirius XM users, where you can just listen to it directly from your phone using the Sirius XM app on your phone. Keep us posted and let us know if you have any more questions! I remain hopeful that the problem will fix itself once you re-do your driver profile and the system has received a software update! Cameron (2021 BMW 330i - named him: "Hrag") |
04-09-2024, 09:02 PM | #3 |
Rep 694
I will try your method of re adding profile.
Software update was done 4 days back and it didn't fix any of the problems! Sadly.
04-09-2024, 09:21 PM | #4 | |
Rep 171
As for the news and spotify apps, what about the alternative methods I listed above? Using/listening to both apps from your phone via Apple CarPlay/Android Auto NOTE: Keep in mind you can also play music/content via "Bluetooth Audio" if you only use BMW's Bluetooth system and NOT Apple CarPlay/Android Auto Let me know if the profile works and what your thoughts are on the possible alternatives! Cameron |
04-10-2024, 08:04 PM | #5 |
Rep 694
In case anyone has similar issue, the ONLY solution was to click the RESET TO FACTORY setting inside the idrive menus.
This then required a COMPLETE set up of the car from scratch. Even the myBMW app required me to register the vehicle again etc. But it left everything working again as it should. Nothing else worked.
05-08-2024, 06:33 AM | #6 |
Rep 22
My news app suddenly stopt working also and started asking for my credentials.
I have deleted my user profile and added it again but no luck. I already lost a lot of settings because of this like seat memory Really resetting everything is the only option...? I would really hate doing all the settings again |
05-08-2024, 06:48 AM | #7 | |
Rep 694
Make sure your guest account seat positioning is the way you like it because that's what it's going to remember. Set it up just like your current main profile positioning. Go back and forth until you are satisfied they match.
