2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Remote start not working
      02-13-2020, 04:49 PM   #1
Medjd11
Drives: 2014 F30
Error message pops up onscreen. Anyone know what's up or know the fix?
      02-13-2020, 04:54 PM   #2
Burrcold
Drives: 2024 M3 Comp xDrive
I was having the same problem. All fixed now. See my thread...
https://g20.bimmerpost.com/forums/sh....php?t=1694369
      02-13-2020, 05:29 PM   #3
Medjd11
Drives: 2014 F30
Tried resetting everything and followed your thread. No luck. Still gives this error message. I even tried updating apps, logging in and out but nothing. The car acts and sounds like it's going to do it via key fob but doesn't.
      02-13-2020, 06:17 PM   #4
Burrcold
Silly question, but you're not low on fuel are you? It won't remote start if you are.
      02-13-2020, 06:25 PM   #5
Medjd11
Drives: 2014 F30
More than half a tank.
      02-13-2020, 06:31 PM   #6
VipinLJ
VipinLJ's Avatar
Are your doors locked and windows closed? It won’t work if they aren’t.
Also, I tried to use remote start yesterday, and it didn’t work. I had switched the car off using the start button like I always do, without shifting to P or hitting the parking brake. Usually it turns the parking brake on, but yesterday it didn’t. And there was no error message. The next time I tried I did remember to set the parking brake before exiting, and it worked. Could that be your issue too?
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      02-13-2020, 06:32 PM   #7
Medjd11
Drives: 2014 F30
I tried to see if there was an update, but it says the software is up to date. This is the software it's running.
      02-13-2020, 10:13 PM   #8
VipinLJ
VipinLJ's Avatar
No OTA updates yet. So it’ll show the software you have as the latest version on I drive even if it isn’t. Maybe time to take it to your dealer for a software update?
      02-13-2020, 11:16 PM   #9
premier3is
premier3is's Avatar
1632
Drives: 2019 BMW 330i M-Sport
If you remote start the car and turn it off using the key fob 2x without getting in the car and driving it, it will not remote start further till you do.
I doubt this is the issue for you, but just mentioning it.
When you remote start and get in the car the parking brake should be on even if you didn't put the parking brake on before you left last.
      02-14-2020, 09:42 AM   #10
VipinLJ
VipinLJ's Avatar
I had no idea. Let me test that out and see if that’s how it works in my car.
      02-14-2020, 09:43 AM   #11
Burrcold
That's how it works in my car as well. I don't have to put the parking brake on to remote start, but it automatically engages when I do.
      02-16-2020, 09:51 PM   #12
G2020VISION
G2020VISION's Avatar
Drives: 20 m340ix
2020 M340I X  [0.00]
Try rebooting the Idrive. My remote start wasn't working via the connected app. I know that's not the same as the remote but give it a shot. Hold down the power/volume button for 20-30 seconds until I drive reboots. It definitely fixed my remote start connected drive issue on my 340
      02-18-2020, 09:26 AM   #13
vincechase
vincechase's Avatar
Drives: G20 330 M Sport
Mine was working but I tried doing it twice since I got home from my drive.
I went for another drive, came home. When I turned my car off it has a screen on to start engine and pre condition car. I believe aslong as that screen shows then you are good to go. It stays active after the car is turned off.
I then went in my house and tried first with my phone and it worked flawlessly. Then again with the remote and also worked. =)
Couldnt start it before work the next day though.
      02-19-2020, 09:47 AM   #14
Peter619
peter619
Peter619's Avatar
Drives: 2021 BMW 530i xDrive
My car recently refused to remote start because of low exterior temperature. An error message popped up saying that, in order to conserve battery power, it would not remote start....
      02-19-2020, 10:05 AM   #15
Burrcold
Strange. It was like minus 30 last week with the wind chill here in Toronto, and mine still remote started like a champ (thanks god).
      02-19-2020, 10:25 AM   #16
VipinLJ
VipinLJ's Avatar
Like Burrcold and premier3is mentioned, car does remote start even when parking brake isn’t on. It sets the parking brake on. I’m assuming my car didn’t remote start that time because my phone had really low charge which I did notice but skipped my mind. It hasn’t remote started before either when my phone had real low charge (<10%). I plug in my phone in my car and by the time I get to where I want to be, it has more charge and remote start worked then.
Remote start has always worked for me even when it was -5F a few days back. I wonder how low the temperature has to be for it not to work.
