03-06-2016, 08:14 AM | #1 |
Rep 88
new hear question on the X5 5.0
New here question on the X5 5.0
I have a 13 X5d low miles no problems except bmw recalls Have come to find no a fan of the diesel. Don't like the sound. Since I only drive around town receive no benefit from a diesel Also have the sport pkg and 20 inch wheels and do not like the heavy steering feel. Want more of a luxury feel Why 5.0 I just want a V8. Have other BMW.s with the 6cyl and are adequate but I just want a V8. Question How are the 2016 v8 in terms of reliability. Know past talk about battery issues and valve-train failures. Has BMW fixed this or is this still a 5.0 issue. Thanks Last edited by 2016sx5; 03-06-2016 at 10:44 AM.. |
03-06-2016, 08:24 AM | #2 |
Herr Oberst
244
Rep 531
It's a 50i, not a 5.0. The engine is 4.4 liters. 5.0 is Mustang talk.
You definitely receive benefit from a diesel on short trips. The diesel's acceleration from 0-50 is better than the 6-cylinder gasser. For short trips, you're enjoying the benefit of that torque. If you care about fuel prices (they will go back up by the way), the 50i will kill you in the long run, especially around town. Expect 10-12 mpg in town. As far as reliability, the sad fact is that Bimmer V8s have never been particularly reliable. Great performers, yes. But as far as the battery issues, no you still get a battery swap at service (this was a factor in buying our 740 instead of a 750). As I mentioned in another thread, my long-time service advisor joked the other day "BMW V8s are great...so long as they're under warranty." Between the oil consumption issues and the debacle of total top-end rebuilds on the E70s, I've owned my last BMW V8. It isn't their bailiwick from a consumer standpoint. In 5-10 years, they probably won't offer them in the US outside of M cars (bold prediction) thanks to reliability, CAFE, and the ability to make power from diesels and forced induction sixes.
'15 X5 35d
'16 740i |
03-06-2016, 10:57 AM | #3 |
Rep 88
Thanks for the reply
Never owned a Ford didn't know was Ford talk, Have a Corvette Gas price is no concern. Around town, drive my 4x4 GMC, 12 is about what it does. Heard many being pleased with the diesel torque but finding my around town is stop sign to stop sign over to Home Depot or wal mart. thinking v8 really just for sound. Like the vettes. Good to hear the comment from techs. What many are saying about the diesel if out of warranty. My type of driving will eventually lead to carbon and expensive out of warranty fix. why starting too look, 7 month left. Sound like in 4 years will be back where am with the diesel, wanting to trade before warranty gone to keep from an expensive repair bill. Thanks |
03-06-2016, 12:58 PM | #4 | |
Herr Oberst
244
Rep 531
'15 X5 35d
'16 740i |
03-06-2016, 02:07 PM | #5 |
Rep 88
diesel motor has been fine. Its the exhaust side. 3 Ox sensors,
new catalyst, downpipe, urea tank. They broke the plastic motor cover, which had nothing to do with motor was just off so much. if had gotten the gas 6 be keeping it longer That why posted wanted to hear opinions on the V8 |
03-06-2016, 04:41 PM | #7 |
Rep 1,170
I have the 50i with only 17,000 miles, so I can't share much about any issues with the engine because there haven't been any issues so far. If you really like the V8 then get it. Sure, it might have some issues down the road but what car doesn't? I've had the X5 4.4i V8 before and it was bulletproof so I guess I'm lucky that I've had only good things to say about BMW V8s so far.
2001 X5 4.4i - sold but never forgotten!
2014 X5 xDrive50i |
03-06-2016, 10:03 PM | #8 |
Mmmmm…
1152
Rep 2,426
Drives: F15
I had N62 on my previous X5, hit about 120k and didn't have issues with regular maintenance. Current car with N63tu about 11k, so far so good. Oil consumption very minimum especially compared to what a lot of people say about these motors.
Get about 12-14 mpg around town. Hit 24 mph highest in highway mostly around 19-20. Average for me is around 17-18 combined cycle. |
03-07-2016, 06:45 AM | #10 | |
Herr Oberst
244
Rep 531
The N63 is to be swapped at every oil change (if not within last 12). Your swap interval should end up the same. The V8s are the original cause, due to higher power demands. |
03-07-2016, 09:01 AM | #11 | ||
Rep 105
So does not matter which F15 X5 model you get, they all require the same battery swap at the same exact interval. Here the link to the actual service information bulletin: http://www.bimmerfest.com/forums/sho...5&postcount=12 F15 (X5) Produced from 8/2013 With the N55, N57, or N63T engine VEHICLES EQUIPPED WITH AN N55, N57, N63T, S63, OR N74 ENGINE This procedure only pertains to the models listed in the attachment (based on the production date) that are equipped with an N55, N57, N63T, and N74 engine. At engine oil service "counter # 2"only, covered under the 4 year/50,000 miles BMW Maintenance Program: Perform a Key Read on the vehicle and check to see if an engine oil service is "Recommended" or "Due" by miles or will be required in the next 60 days or less. Confirm the battery was not replaced previously during the last 12 months. If the results of steps 1 and 2 allow, replace the battery together with performing the engine oil service. Important note: Do not perform an energy diagnosis for this battery replacement. Refer to ISTA Repair Instruction 61 21 010, "Remove and install or replace battery." Register the new battery using ISTA. Refer to SI B61 15 12. Select the "Enter battery replacement: same capacity," and then the replacement is finished. The N63 was in the E70 X5 (2nd generation X5) and earlier 3/2010-6/2013 F10 550i models....which would need battery change at every oil change. The N63T is in the 2014-2016 F15 X5. (Current 3rd generation X5) |
03-07-2016, 09:10 AM | #12 | |
Herr Oberst
244
Rep 531
I think with the "if not replaced in the last 12 months" provision, you'd end up with the same interval regardless. Who drives less than 10k a year?! I'm at 22k in 10 months
'15 X5 35d
'16 740i |
03-07-2016, 09:15 AM | #13 | ||
Rep 105
In terms of reliability and cost to maintain, I agree the V8s will be more costly. The N63 engine was a dud of a V8. Hopefully, the N63tu will fare better than the N63 and time will tell. However, in my honest opinion, none of the current BMW turbo engines will be as reliable as their previously normally aspirated inline-6/4 cylinder engines... |
03-07-2016, 09:54 AM | #15 |
Rep 5,066
Here is my take... if you can afford the V8, get it... you will enjoy the power immensely regardless if you drive around town or on the highway. If you can stretch your budget even more, then get the X5M... its a completely different experience that you will never get with the 50i, 35d, 35i.
Life is just too short and not many people even keep their cars past 5 years.. most get the itch to get a new one by this time. If there is an issue with your V8 for the first 4 years, BMW will take care of it.. the last remaining year you can take the risk and just enjoy the hell out of it. Rinse and repeat..
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
03-07-2016, 10:28 AM | #16 |
Mmmmm…
1152
Rep 2,426
Drives: F15
If you think to you may have battery issues, just get the wall charger and hook that up once month.
03-07-2016, 10:45 AM | #17 |
Rep 1,181
OP, just get the 50i and be done with it since you stated from the get-go: "I just want a V8". Battery issues and what not surely aren't ever going to sway your decision. It's not like the V8 "blows up" over time. The rest is just the risk we all take after the warranty has expired.
A little mod here, a little mod there...
03-07-2016, 01:28 PM | #18 | |
Herr Oberst
244
Rep 531
As for mileage, 49 miles one way to work will do that. I rack up 500 miles a week just getting there and back.
'15 X5 35d
'16 740i |
03-12-2016, 07:21 PM | #19 |
Rep 88
Well,,, my saying just want a V8. Didn't work. I test drove 3, and 2 3.5i.
Told the salesmen sure like the sound of the V8. His reply, which of the cars did you like driving the most. Had to admit was the 35i. We did not take the cars out, where could open up, because wanted to drive the route where 90% of my driving is. In town, urban.. Maybe because the 6 is lighter in front and felt better in the city, it didn't feel like past 6cyl. He told me has many come in going V8 V8,,, gets them in a 6, pleased. For rumble, can start up my GMC Sierra with the Corsa's LOL So traded the diesel. Night and day, the new steering is great. Made the 2013 feel like truck. Not missing the clatter of the diesel. My diesel on the best mpg was 25. The 35i is better. Salesman told me all had to say was steering on the 2013 and knew would be sold on the 2016. What got was a Space Grey, White interior, with some kind of M pkg. But not the wide wheels. Still like BMW X5's best. Did test a Porsche, Lexus and a mammoth Escalade. |
03-12-2016, 07:31 PM | #20 | |
Rep 105
