12-04-2016, 09:34 AM | #1 |
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
Hi all,
I read on here recently a post that had an attachment document for track settings. It was two pages. I now can't find it. I did find a small table in pic for suspension settings for the Ring and basic race track but not the info for the the wing and it is very brief. If anyone could point me to that or post it here. I'm going next weekend and would like to set the car up correctly. (FYI the manual is in the glove box at the wrap shop until Thu, so can't access it). Thanks in advance.
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
12-04-2016, 11:24 AM | #2 | |
Rep 302
Drives: 1M
12-04-2016, 03:23 PM | #3 | |
Rep 10,185
Or this one
But think he is looking for the manual info ? Quote:
BMW if you are reading, I need a job, Please. Last edited by E90Fleet; 12-04-2016 at 03:52 PM.. |
12-04-2016, 06:47 PM | #4 |
Rep 1,758
Nope. I have that. It had some more text.
I think I need to read the manual when I get my car back next week (when all else fails...)
Current non-BMW's
12-05-2016, 08:47 AM | #5 | |
Rep 261
Drives: M4 GTS, M3 GT4, E30 M3...
12-05-2016, 11:13 PM | #6 |
Rep 1,758
YESSSSS Exactly
Thank you!!
Current non-BMW's
06-26-2019, 11:25 PM | #7 |
Rep 855
Just wanted to confirm, when BMW states X clicks open in their literature, can you confirm:
1) they are starting from maximum stiffness in the shocks (- all the way to full +) 2) that they mean turning the knob setting from + to -, essentially going from full stiff to soft in X click increments? |
06-27-2019, 07:46 AM | #8 | |
Rep 3,422
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
06-27-2019, 12:20 PM | #9 |
Rep 855
anyone comment on why the TRACK settings (rebound and high speed comp) above don't match the supplementary owner's book pdf that was posted? .
Which one is the correct one? |
06-27-2019, 01:46 PM | #10 |
Rep 3,422
Weird, didn't notice the inconsistency. Use the official pdf recommendations. Not sure where the other image came from.
06-27-2019, 03:16 PM | #12 |
Rep 3,422
Yeah? What are you running and how'd you get there?
06-27-2019, 03:46 PM | #13 |
Rep 2,336
I typically am at www.area27.ca as we are members. Very technical track. High speed, low speed and rebound are very track/driver specific. The factory recommendation is a good neutral, but this is why the GTS is special. It's very analogue and changes drastically to proper chassis tuning.
06-28-2019, 04:59 AM | #14 | |
Rep 321
Changing aero settings would likely change the required shock settings |
06-28-2019, 06:00 AM | #15 | |
Rep 3,422
thanks
06-28-2019, 11:31 AM | #16 |
Rep 2,336
Biggest changes for me was really slowing down rebound and stiffening low speed comp(my high speed comp is set softer than track setting). At track setting it would unload too quickly over crests and g outs on our track. This track has fast but smooth transitions, not choppy or sharp transitions. I would advise you to throw your key to the club pro and get their input on setup.
06-30-2019, 06:41 AM | #17 | |
Rep 3,422
07-01-2019, 09:55 AM | #18 |
Rep 261
Keep in mind the "Track Settings" are based on BMW's baseline for the Nurburgring. All tracks are going to require a different setup in order to optimize the cars potential. Other variables include driver weight and driving style, aero, weather, track temperature, track surface type, tires etc.
I would suggest having the car corner weighted with the driver first and then making your adjustments from that point. Make them one at a time and note the difference in feel and lap time keeping all other variables as constant as possible. That's the best and only way to achieve a proper setup. That is why race teams do so much testing. |
VCP1390.00 |
