03-23-2017, 10:54 AM | #1 |
Faster on 2wheels
131
Rep 381
M4 GTS Track Setup
I know these cars are built for the track...but does that mean any customizations would degrade it's performance?
I'm considering wider tires and possible a different ET setup for the track. Thx in advance! |
03-23-2017, 11:24 AM | #2 |
Rep 182
Before doing anything, you need to drive the GTS on the track. This is an incredible car and you will be surprised by its capabilities. Two suggestions for your first time out:
1) remove the spacers to lower the car. 2) dial in a couple more degrees of negative camber. After that, you can modify as needed to improve your track time/experience. |
05-05-2017, 10:52 AM | #3 | |
Rep 166
Carrera white 991 GT3
Brilliant white M5 69 Plymouth RoadRunner 472 HEMI 68 528 hemi dodge dart 69 598 jon kaase boss mustang |
05-07-2017, 02:33 PM | #4 |
Rep 762
I would never drop the car by removing C clips and not follow M:s recomendations on rebound/compression.
The main point of the 24months of GTS development was among other thing, get the 2 prefered best overall settings. Wich make It very easy for us owners, Hence the chassie guru Jorge W at M like did 50000km in the car, at street and track, short and long. Hence we got 2 settings wich would be very solid for the 95% owners. The rest of the 5% that bother and got the time, skills and buget could get the car even lower and slightly more camber(in stock form) etc. and match the car for personal driverstyle. Follow BMW M setting, and It will not roll or ptich at all on track. It will drive totaly planted, and you will make better use of tire. Its like 2500 way of setting the 3way KW chassie including aero on GTS. One must know what one do, its very easy to go wrong and you have a less preforming car. Then again there are people who will succed. I recall -2 is the most Anybody get in GTS by just removing c clip. |
Rasya36.50 |
