09-07-2017, 11:26 PM | #1 |
Rep 502
I wanted to inform the community I have had a crank hub spin on new bedplate design.
Initial failure was a full engine replacement by dealer in June with the new bedplate design. (JB4 only) This time new engine crank hub slipped and timing jumped 60 degrees. (Pic attached) It happened while on the dyno (570hp/638tq) in August. Mods this time were JB4, DP, Meth and drop in filters. To reset timing cost me $6k for parts and labour including exhaust vanos failure and install of Vargas Crank Bolt Capture. (Testing this now with Pure Stage 2 turbos) I am a sucker for punishment. Additional car details are F80 August 2015 build, DCT, May 2017 New Bedplate design Engine. Bedplate redesign may have helped but is not the solution.
Sunset Orange G20 M340i
PAST F80 LCI/M3/AW FBO BM3 Cary Tuned Meth/Pure Stage 2 F36 CB 435i FBO F15 GS X5 50i Tune F10 AW 550i Loaded/Tune/M5 Exhaust |
09-08-2017, 12:23 AM | #2 |
Rep 656
I thought the new bedplate design did not happen until Dec 2015 Builds?
If yours is August 2015 , then it is not the new bedplate design.
///M4 | AKRA Evo & DP's | Brembo GT BBK | MSR CAI & CP's | MPSC2 |
Suspension : | KW CS 3-way | Dinan Toe Links | GC ARWJ & End links | IND Shims | SPL Control arms & End links | aFe Bars | |
09-08-2017, 12:24 AM | #3 |
Rep 502
I had the new engine with the new bedplate design installed in June.
09-08-2017, 09:42 AM | #4 | |
Rep 66
09-08-2017, 09:46 AM | #5 | ||
Rep 502
09-08-2017, 12:29 PM | #6 |
Rep 966
Dang. Sorry to hear that.
Even with the new bed plate design. My front hub has spun twice. New friction disc update but with original bedplate design. My local shop recently received their clients F10 M5 engine built from Steve Dinan's new shop SD AutoTech. My repair shop is currently removing my S55 engine to send to Steve Dinan for full build. They are keying the crank and upgrading pistons, connecting rods, cams, etc. |
09-08-2017, 01:13 PM | #7 | |
Rep 1,336
09-08-2017, 01:48 PM | #8 | |
Rep 966
I can not disclose that at this time but he has a website with their contact information. https://sdautotech.net/ |
09-27-2017, 04:02 PM | #11 |
Rep 502
Nope it has the bedplate long block part number.
09-29-2017, 04:58 PM | #12 |
Rep 1,012
The 6-spds rarely ever spun their crank hubs without it being because of a miss shift and massive overrev. I think out of literally thousand upon thousands of M3/4's their been ONE verified case of a none money shifted 6-spd crank hub failure. And zero failures at stock power level with no misshift so I doubt you'll ever hear of the new bedplate design in 6-spd failing. ps: VTT already has a solution that hasn't failed for this yet. Same with maximum PSI, and TPG...
09-29-2017, 06:42 PM | #13 | |
Rep 1,376
09-29-2017, 11:50 PM | #14 | |
Rep 674
Sadly and reluctantly I honestly wouldn't feel safe with any S55 at this point as I feel like its only a matter of time... |
10-01-2017, 10:58 AM | #15 |
Rep 1,012
Yes, yours and a highly modded upgraded turbo car too. Regardless thou, no need for that sad attitude! We have *several* very promising and affordable solutions to that problem that have been holding up fine at 700+whp now..
10-01-2017, 12:45 PM | #16 |
Rep 1,039
If this was so pervasive why wouldnt bmw fix it by now? Especially if the fix was relatively cheap.
The warranty claims as well as public image would become an issue. |
10-01-2017, 01:28 PM | #17 |
Rep 1,012
10-02-2017, 11:43 AM | #18 |
Rep 2,997
Because it's not pervasive at all on stock or even near-stock engines?
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
10-05-2017, 12:41 AM | #19 |
Rep 626
Will BMW ever put out a recall for this issue? This has been going on long enough and a class action suit needs to be brought up against them IMO.
10-05-2017, 07:38 AM | #20 |
Rep 6,867
SYT_Shadow11500.00 |
10-05-2017, 07:46 AM | #21 | |
Rep 4,265
FirstF80InSpace343.50 kingofqueenz78834.50 |
