06-07-2019, 08:35 PM | #2 |
<3 Flat Four
217
Rep 754
the warning that comes on when u reach a certain speed? or the automatic increase in volume according to vehicle speed? either way both settings can be found within idrive settings...
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White |
06-07-2019, 10:13 PM | #3 |
Rep 592
06-08-2019, 02:51 PM | #5 |
Rep 7,532
You can decrease or increase how much the volume adjusts based on your speed. How do you have your SPEED VOLUME set? If you don't know...see the 4 pics below that shows the quick 4 steps it takes to get there...you select/press the red highlighted selections to advance to SPEED VOLUMNE in your iDrive to make the changes:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-08-2019 at 03:06 PM.. |
06-09-2019, 04:22 PM | #7 |
Mmmmm…
1152
Rep 2,426
Drives: F15
Speed volume on the one bar setting seems to disable it...
2015 BMW X5 xDrive50i
BMW CCA 509766 |
06-10-2019, 12:41 AM | #8 |
Rep 7,532
When you get to the screen above...are you scrolling your iDrive controller to see if there are more options than what is appearing on the screen?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
06-10-2019, 05:44 AM | #9 |
Rep 592
06-11-2019, 11:41 AM | #13 |
Rep 7,532
Well...since it seems you don't have it...and not knowing when you originally posted that you had the B&O set-up...looks like it's explained in the owners manual when I turned to it looking for some clarification.
06-11-2019, 12:21 PM | #14 |
Rep 592
06-11-2019, 02:25 PM | #15 |
Rep 1,452
Huh, I have a 2015 with B&O and I can adjust mine (at least I think I can). I'll double check when I'm in the car next and make sure I'm not confusing it with my M3.
06-14-2019, 09:05 AM | #16 |
Rep 7,532
Did you get a chance to check if your B&O system allows you to adjust for speed volume yet?
06-14-2019, 01:19 PM | #17 |
///M
193
Rep 272
Drives: 2015 F15 X5 50i M Sport
I have B&O and just checked. I don't have the option. 2015MY
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
06-14-2019, 08:26 PM | #18 |
Rep 7,532
Ah...thanks for the confirmation. I guess this is info I need to add to my "mental Rrolodex".
06-15-2019, 06:53 AM | #20 | |
Rep 1,452
No. Try not. Do. Or do not. There is no try.
-Yoda |
