07-23-2019, 06:21 PM | #1 |
Rep 14
Staggered wheel set up and X Drive
Been looking to do a mod and get new wheels and tires.
Spoke to a contact at local dealership and he said not to do it - it will ruin the x drive. Will end up dropping $8k on a new transmission. He said if you want that look, just buy the M. Is this true? Will having bigger wheels in the back mess up the x drive? If so, is the solution just getting spacers in rear so they "appear" to be bigger tires? Thanks - I did try to search through threads but didn't find anything that addressed this directly. When I type in my 2016 F15 x-drive 35i into BMW's site, it pulls up wheel options and the rear is larger. So I am wondering if I'd be good. |
07-23-2019, 06:41 PM | #2 |
Rep 535
Not true at all. Hundreds of people in this forum literally are running staggered and bmw sells them officially when you order a new car. You dont get a different car just because you ordered a staggered setup.
Here is the thing though - make you wheels are OEM spec, tires are new and star marked since the x drive is very picky on mismatched sizes. Doing that will mess up your differential (not transmission). I have oem 21 wheels and oem star marked tires. Handles better than square actually.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi |
07-23-2019, 06:49 PM | #3 | |
Rep 14
07-23-2019, 07:25 PM | #4 |
Rep 299
Yeah BMW's own 21 M wheels are staggered. I have been running staggered 22's for a year. As the other poster said, you want to make sure the rolling circumference is the same (or very close to less than like 1% difference) between the front and back.
If memory serves me, I have like 295 in the front with a 30 sidewall and 325 in the back with a 25 sidewall. When you put in the calculator, it is like 1.5% difference. Xdrive will hate you for anything over a few percent. |
HJ478.00 |
07-23-2019, 07:58 PM | #5 |
Rep 535
I did not stay with RFTs. Here are your two oem sizes:
1. (front) 285/40R20 (rear) 325/35R20 2. (front) 285/35R21 (rear) 325/30R21 Again, my advise, buy new tires and dont look for used ones. BMW also sells this: https://www.shopbmwusa.com/PRODUCT/4...--COMPLETE-SET
HJ478.00 |
07-23-2019, 08:31 PM | #6 |
Rep 2,515
Your dealership person is not competent, staggered set up was offered by BMW with new vehicles as well as they are selling wheels and tires packages. Nothing to worry about as far as you get the right configuration with proper circumference. And I would ditch RFTs.
07-24-2019, 09:41 AM | #7 |
Rep 224
You can use the tire size calculator at 1010tires to check the circumference of tire choices. But as others have said staggered from the factory on x drive is common. You can also get rid of RFTs if you so choose.
11 BMW E93 M3-- 06 BMW Z4M Roadster
99 BMW M Coupe -- 85 BMW M635CSI 97 M3 Coupe (Track)--95 BMW M3 Coupe 91 BMW 850i 6MT--20 Ram 1500 16 Chevy Tahoe 4WD |
07-24-2019, 09:54 AM | #8 |
Rep 14
Maybe he was more concerned with offset (spacers) than the staggered set up? I can't remember now. And this may be a really dumb question (apologizing in advance) but what are star marked tires (as opposed to square)?
07-24-2019, 02:10 PM | #9 |
Rep 224
A star on the sidewall means that BMW worked specifically with the tire manufacturer to optimize ride, handling, and noise for the specific vehicle. For example you can buy a Bridgestone Potenza with or without the star and there will be some differences. Now, tracking down what those are specifically would be a chore and it will be different for every platform. For example the tire sidewall is thicker, or the tread is a slightly different shape, the tire may be .05in taller or shorter, etc... Using the star tire on your BMW is supposed to provide the most optimized driving performance per the engineers. You can however safely run any tire you like and the result will vary. It isn't likely you would damage the vehicle in any way. I suppose you could see some degradation in certain areas with different tires. People will debate all day on whether this is marketing BS or there is some benefit. One thing is for sure, you'll pay more for a "star" tire. I've switched from starred RFT's many times and found performance to be considerably better, especially in the ride category. Once my X5 RFTs wear out I will replace them with go-flats. My personal opinion is I've owned probably 15-20 BMWs and always bought tires based on price/performance and never given a second thought to star denotion. Buying a star tire is never a wrong answer, but it is likely an expensive one.
TaraRene0.00 |
07-24-2019, 02:27 PM | #10 |
Rep 535
My personal opinion is exactly opposite. Not arguing but I happened to get 2 non star marked tires for a staggered on my 7 series and that threw off the differential a few years ago. I guess once it happens, its changes how one thinks. The car was undrivable (had to put my winters back on) and it was never the same even after buying two star marked tires so I ended up selling it. Paying few hundred dollars more while buying vs. taking a few thousand dollar gamble with some of these newer complicated machines.
07-24-2019, 11:50 PM | #11 | |
Rep 1,340
07-25-2019, 03:08 PM | #13 | |
Rep 224
07-25-2019, 04:34 PM | #14 |
Rep 560
As others have said, stick preferably with OEM wheels and the correct tires will be specified for those wheels.
It is all to do with the rolling diameter of the tire. For example, 19 inch wheels will have the same overall diameter tires as 21 inch wheels - they will just have different sidewall depth to compensate. |
07-25-2019, 06:43 PM | #15 | |
Rep 535
So I don't think its all balonies. If you google stagged x drive and differential failure there are lots of people having issues. I personally think we underestimate the unequal wear on used tires and how it affects the diameter and thats when the issues pop up.
07-25-2019, 08:57 PM | #16 | |
It's always something.
11
Rep 24
07-25-2019, 10:13 PM | #17 | |
Rep 1,340
07-26-2019, 12:58 AM | #18 | |
<3 Flat Four
217
Rep 754
u guys r making this all too complicated. as long as the tread depth difference is less than 2mm then ur ok. star designation or not, as long as all 4 have the star or not is ok, not a mix of 2 stars n 2 non star tires. if we look at our staggered oem tire sizes, the overall diameter works out to be exactly the same at 28.7".
the overall diameter r as follows: star spec = 25.2" tpc spec = 25" generic spec = not listed so as u can see, even tho all 3 versions r marketed as the same size, the difference is 5mm. putting the tpc spec tire on while the opposite axle has tires that r 25.2" will automatically exceed the allowable tolerance of 2mm n cause the xdrive system to go out of whack.
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White Last edited by TOPEC; 07-26-2019 at 01:10 AM.. |
08-16-2019, 12:49 PM | #20 | |
Rep 289
As others have mentioned, so long as the tire wear is even on all 4 wheels, and you stick to the correct sizes, you should have no issues with the X drive, although I would always recommend to buy new tires if at all possible. I personally have 612 replicas from Italy (https://www.makwheels.it/en-ww/x-mod...m40izx.aspx#!/) and Goodyear Eagle F1 Asymmetric 3 SUV tires, and I love it...
2014 X5 35i Sophistograu A90 (Dark Graphite) Terra Dakota
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr Last edited by ems328i; 08-16-2019 at 12:55 PM.. |
08-16-2019, 12:51 PM | #21 |
Rep 289
Adding rear spacers, providing you buy ones that are the correct fit, should give no issues at all.
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr |
gregdestep23.50 |
