06-23-2021, 08:49 AM | #1 |
Rep 3,033
Drives: 2019 M2 Competition
Easy upgrade - Mishimoto oil cooler DIY
Hope everyone is having a great week! My latest video is up! I wanted to share it out as hopefully driving, events, and track season is coming!
Oil temperature really matters and helping your motor to cool faster is a big deal! The Mishimoto Automotive oil cooler upgrade for the S55 motor can make a huge difference! If you tune your car or run in a hotter environment (or both!), keeping oil temps down is critical. Check out this easy DIY change from Kies Motorsports and see how you can easily do this too!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
06-23-2021, 09:03 AM | #2 |
BimmerPost Supporting Vendor
24342
Rep 191,109
06-23-2021, 06:37 PM | #3 |
Rep 3,033
06-24-2021, 02:51 PM | #4 |
Rep 3,729
What did you see as a reduction in oil temps?
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
06-24-2021, 05:17 PM | #5 |
Rep 3,033
Not enough driving yet honestly.. I have older BM3 logs I could use as a baseline when I get a chance.
06-25-2021, 10:01 AM | #6 | |
Some random guy
292
Rep 312
But, as far as impact on IATs and oil temp, I haven't noticed a hugely significant reduction. The IATs tend to run 18*F over ambient now while cruising (would average around 20-25*F over ambient with OEM - although there was a leak from the TMIC, so low fluid levels could have been a factor in that). Oil temps tend to hold right around the OEM setup values for Efficient/Sport and Sport+ modes. Now, what I have definitely noticed is better consistency in these temps and quicker return to baseline temps when banging on the car.
BMW DIY Guy3088.50 |
07-03-2021, 01:16 AM | #7 | ||
Rep 3,729
One thing that I've noticed is that thicker oils will retain heat and it will be harder to dissipate even with upgraded oil coolers. This is just simple physics, but I've proven that with data logs. It will take quite a while for my oil temperatures to drop from efficient mode to sport plus mode. I am currently running Motul 300V 5W-40, which is a bit on the heavier side of 40 weight oils. I am likely going to drop back down to Quaker State Ultra Euro 5w-40 since it is a thinner 40 weight. I noticed my oil temps are lower overall and drops much quicker with running a lighter oil. Also, oil analysis proves that the Quaker State oil is essentially the same as Pennzoil Euro 5w-40 except it has a stronger base oil to withstand longer drain intervals (50f increase in flashpoint). It is also $18/5 quart jug at Walmart hehe.
07-03-2021, 06:54 AM | #8 |
Rep 4,203
Looking at the cooler shape it looks like those that upgraded to the Turner/Fall line skid plates might have fit issues. With the different shape it looks like the skid plate might no longer fit with the upgraded oil cooler. Hopefully someone can confirm
07-03-2021, 08:48 AM | #9 | |
Rep 154
Drives: F80 M3, E92 328i
hellokitty2897.00 |
07-03-2021, 09:47 AM | #10 |
Some random guy
292
Rep 312
Same here. I don't have a pic ATM, but can confirm fitment with combo of Mishi oil cooler, Turner skid plate, and CS front spoiler.
Minor modification was necessary on the skid plate to accommodate the spoiler, but nothing that took more than a Dremel and some patience.
07-03-2021, 09:58 AM | #11 |
Rep 4,203
You guys rock...thanks for the confirmation
07-03-2021, 10:10 AM | #12 |
Rep 3,033
Absolutely fits.. there is a rubber gasket thingy on the back edge of the Turner plate you will need to take off.
07-03-2021, 11:22 AM | #13 |
Some random guy
292
Rep 312
Ahh, yes. I recall that step now. Although, I used a razor blade and trimmed the rubber down to maintain the seal against the cooler edge.
