12-08-2022, 04:59 PM | #1 |
Rep 8
6wb cluster problem
Hi everybody. I have a situation with the 6wb cluster, all configuration is fine and it appears well in the cluster, except where it shows the speed. everything is in miles but there it stays in kilometers, no matter what you adjust the settings. At first everything was fine and I think this happened after an oil change reset. Suppose some code corrupted.
12-10-2022, 03:29 PM | #2 | |
Rep 7,529
If I select (digital) MPH to appear at the top of my speedometer using coding software (like BimmerCode)…then kilometers appear where you have it circled in yellow. If I select (digital) kilometers to appear at the top of the speedometer gauge, then miles appear where you have the yellow circle. Did you do any coding that you didn’t mention in your original post? EDIT: just remembered that the area you have circled in yellow is also the 6WB cluster’s OBC display….so what happens if your press the BC button on the tip of the turn indicator stalk? You may be seeing a selection from your OBC choices…but if you press the BC button and it scrolls through the other selections…the problem is not that your speedometer selects are wrong…you just have the OBC info being displayed. If you have the car turned OFF (yes, totally off)…then briefly press the odometer reset button (this should bring up the odometer for approx 5 seconds)….what do you see when your mileage appears…miles or kilometers?
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-10-2022 at 03:54 PM.. |
