02-11-2023, 08:02 AM | #1 |
Rep 1,497
Diagnostic Scanner Fuse?
Had a CEL pop up on me yesterday. Just so happened I was close to an O'Reilly's so I tried to have the code read. Guy told me the scanner tool couldn't connect. He said it was more than likely a blown fuse, cutting the power to the OBD2 port. Hmmm, wonder if this was user error of if he indeed is guiding me correctly? Car was running fine, but I did notice excessive radiator fan noise coming from under the hood. Fan was running as if it was a 100 degree and I was pushing the car hard. Neither one of those hold true though. Been looking at fuse diagrams. #11 looks promising. Appears to be in the BDC on passenger side. Is this hard to get to? Any of you guys encountered this?
02-11-2023, 09:06 AM | #3 |
Rep 1,497
Valid point. I have Bimmercode, but it doesn't read codes. Like you said I'd need bimmerlink. I'm going to swing by Autozone today and confirm it wasn't user error. I'll update after.
02-11-2023, 11:46 AM | #4 |
Rep 811
Drives: BMW X5 XDrive35i
Highly recommend the BimmerLink investment dude. $30 some odd dollars to be able to scan the car on demand and clear codes is worth it and has saved me headaches a view times. Also your tuning software (BM3 or MHD) can scan and clear codes.
2017 X5 XDrive35i X-Line | Sophisto Grey | MHD Full Flexfuel Tuned | Mosselman Turbo| Sutphin Tuning TCU | Nostrum Stage 2 HPFP | ER Charge Pipe | BimmerHausPerformance Intake and Inlet | ApexBuilt Catted DP | VRSF FMIC | Zeitronix Flexfuel Kit | KateCool Oil Cooler | Variant Wheels | Conti DWS06+ |
02-11-2023, 01:25 PM | #5 |
Rep 2,514
You can get to BDC and check https://f15.bimmerpost.com/forums/sh....php?t=1786146
02-11-2023, 04:00 PM | #6 | |
Rep 1,497
On a side note, can BM3 app monitor engine temps? It's beyond me why BMW decided to give us oil temp and not engine temp on our gauge clusters. Or at least that's the case on my '15 cluster. |
sukhk5272186.00 |
02-11-2023, 04:02 PM | #7 |
Rep 1,497
So, like I thought it was O'Reilly user error. Autozone had no trouble scanning the codes, so obviously no fuses are blown. I'm going to start another thread on the codes it found.
sukhk5272186.00 |
02-11-2023, 08:58 PM | #8 | |
Rep 811
M302_imola842.50 |
02-11-2023, 09:59 PM | #9 |
F15 daddymobile
2352
Rep 3,516
bimmerlink is $30 and used the same obd that you use for bimmercode. why wouldn't you already have it is the question! 😆
