View Poll Results: I am experiencing a drone noise | |||
Yes | 49 | 52.13% | |
No | 45 | 47.87% | |
Voters: 94. You may not vote on this poll |
06-01-2011, 06:03 PM | #1 |
Rep 1,555
Poll: The 1M Drone Syndrome
I am experiencing I think a exhaust drone with my 1M.
It occurs @ 2300RPM and 70 mph in sixth gear. it gets noticeably louder inside compared to going 55-60 mph. I will try to measure with a DB meter over the week-end to see the difference, and will post results. UPDATED** I have taken measurements in the car driving in 6th gear from 55-70 mph, lowest reading I got was 86-87 db, when drone is present I got peak readings of 97db. UPDATE 2 After 2000 miles I can report the problem has not changed. Driving on the highway, no hills, steady gas the noise inside the cabin will go up by almost 10db and disappears, then come back. It is not a steady loud noise.....
2011 E82 1M VO
2013 F84 35i VO Last edited by discoboy1; 08-29-2011 at 08:37 AM.. |
06-01-2011, 07:01 PM | #3 |
Rep 612
Drives: On a good day, AW 1M coupe
Is this something that's "fixable," and if so, what's the likelihood that BMW will be able to make an exhaust adjustment through the dealer network?
Unfortunately, the small 1M community doesn't have clout in numbers, but maybe BMW will still address this suspected issue. Drone can be a real killer. Can make you fall out of love with a car! |
06-01-2011, 07:35 PM | #4 |
Rep 391
06-02-2011, 12:14 AM | #6 |
Rep 86
Drone 2
"I am experiencing I think a exhaust drone with my 1M.
It occurs @ 2300RPM and 70 mph in sixth gear. it gets noticeably louder inside compared to going 55-60 mph." This is exactly what I have been experiencing. Definitely can be annoying on the highway as it is constant pretty loud. |
06-02-2011, 04:19 AM | #7 |
Rep 57
I exprienced it, but i came from very loud car. It does not bother me much. If it is intended drone for extra HP or performance boost, I am okay with it. If it is just half ass job, then they better fix it.
06-02-2011, 04:34 AM | #8 |
Rep 1,333
I think mine is getting better with miles. Just done a reasonable trip of 150 miles and the exhaust still isn't quiet but it was fine given it's a performance car!! Sounds nice outside so accept there may be a trade off in the car. Overall brilliant package. Almost run in and and an opportunity to open her up. Wow!! It's quick away from the lights and that mid range poke is very very impressive.
06-02-2011, 04:49 AM | #9 |
Drive carefully :)
Rep 322
That's bad. I experienced exacty the same 'drone' with the AC-Schnitzer exhaust. A drone at appr. 2300 revs 6th gear (70 mph) or 110/120 Kph. The drone was really annoying. I removed that exhaust asap, and put on the OEM exhaust back on. Problem solved. No drone anymore. With the 1M///, the problem can't be fixed that easy As for performance? No difference at all between the exhausts: still 382bhp and 565 Nm (all cranck numbers).
06-02-2011, 08:31 AM | #12 | |
Rep 612
06-02-2011, 08:39 AM | #13 |
I'm on that Orange Crush
36
Rep 195
With just over 1000 miles on mine, the drone has significantly decreased, although there remains a deep tone between 2100-2900 rpms. When I say deep, it would probably be compared to my STI when I had just the axle-back portion of the exhaust done. It shouldn't be a downer, as most of us realized that this is not your average 135, so we should expect more noise to a reasonable extent.
I recommend getting to the first oil change at 1000 miles before lodging a complaint to your dealer.
“Speed has never killed anyone, suddenly becoming stationary... that’s what gets you.” Jeremy Clarkson |
06-02-2011, 09:14 AM | #14 |
Rep 820
the drone this morning was half as bad...but it was 20 degrees cooler than yesterday, maybe its heat/humidity dependent.
Its something that i can live with, and it has a sweetspot = 2300-2400rpm in 6th, outside this range and its drone free. (at least for me) |
06-02-2011, 11:25 AM | #15 |
Rep 485
To update everyone following this thread.
I have contact BMW Canada and have opened a case # in regards to the concern/ issue that many are having with their vehicle. I am going to the dealership to drive the vehicle with both their shop foreman and the service manager. I suggest that others pick up the phone and contact either BMW Canada, BMW USA, BMW North America, BMW UK etc etc and start similar cases. In this way we can all learn and contribute to BMW's knowledge pool and help sort out a solution as to why some are experiencing the issue and others are not. Update: June 2 2011 Dealership: Took a ride with the Service Manager and the Shop Foreman this afternoon after contacting BMW Canada customer Service in regards to this exhaust Drone. The Service manager and the Shop Foreman BOTH have said, yes that is a drone. However, both noted that "although we hear a drone it does not necessarily mean that there is a problem with the system". The Shop Foreman indicated that the resonance from the Drone appears to be originating all they way a the header's of the exhaust system and travels all the way down the system to the exhaust. In Sum: The dealer is leaning towards this drone being a design feature/ characteristic of the vehicles performance. What the Dealer has done: They have contact their Regional Technical representative who will be involved in the loop pertaining to this situation. Once they hear back from the Regional Technical rep. they will get back to me with an answer. BMW Canada customer Service They are documenting the whole experience as it happens. They are in agreement with the dealers who have contacted the Technical Rep. BMW Canada wants to wait and see what will happen with this situation as it unfolds. I will continually update the thread as the story goes on... Last edited by rapter; 06-02-2011 at 03:33 PM.. |
06-02-2011, 06:24 PM | #16 | |
Rep 1,555
2011 E82 1M VO
2013 F84 35i VO |
06-02-2011, 06:35 PM | #17 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
Drone is precisely why I went with the DINAN exhaust over other manufacturers with my E90M3. If in fact there is 'drone' especially at cruising freeway speeds this is in my opinion a design flaw. Tuners are able to develop sportier high flow after market exhausts without drone if they do the proper R&D. I'd be interested if the 1M internals of the exhaust has a Helmholtz chamber or not.
06-02-2011, 09:54 PM | #20 |
Rep 612
This is a great question, and would really be interested to hear an expert weigh in.
Yes, I intend to track the car, but also commute with it. Believe me, drone gets old fast (depending on how loud and at what speeds, of course). If the 1M drone is in fact most pronounced at 70mph, and isn't "fixable," it's a deal killer for me. |
06-03-2011, 04:17 AM | #21 |
Rep 440
this is interesting. since i already placed the order with an aftermarket exhaust without the actual car being delivered, i'm wondering if it would help or worsen the drone issue. knowing the drone doesn't really related to loudness, i can't wait to get mine in few weeks to test it out.
btw, i don't think this would be an issue elsewhere or even for myself. driving around 70 mph on fwy... that's just so not going to happen with me in the 1M. i'm not worried, at all. |
06-03-2011, 04:31 AM | #22 |
Supreme Allied Commander
3883
Rep 54,470
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
May I ask which system you ordered? As fas as I know there isn't anything out there for the 1M yet, at least not a production system.
