10-11-2011, 01:11 AM | #1 |
Rep 122
X6 5.0 Dyno Results
Hi,
Mine is 5.0 2010 Last week I’ve raced Cayenne TT 2008 And the result was shocked me... He won it with a far away from me.. We've tried on rolling 40KM, and from 0 On both he won them! After I have run a Dyno on my car, And here is the result. The result 351hp per wheel Is it normal on X6 5.0 Stock?? Thanks |
10-11-2011, 09:51 AM | #2 |
Rep 1,828
Drives: 2016 Tesla Model X P90DL
You realize that Cayenne TT has extra 100hp right?
X6M can beat this Porsche Your other option is tune/flash to get additional power |
10-11-2011, 04:16 PM | #3 |
Rep 122
10-11-2011, 11:10 PM | #4 |
2nd to None!
42
Rep 296
Drives: M8 GC, M5 30Jahre, X6 50i
"Flash" means re-program or reload your ECU...
10-12-2011, 08:30 AM | #5 |
Rep 1,247
When you jump on the forum, search for "tuner chip" or "juice box" and you will find lots of talk about people that have done flashes to their engines and gained about 50 -80 WHP... including my self...
I am shocked at those numbers coming from an X6 50i though...
Too smart for my own good...
10-27-2011, 05:18 PM | #7 | |
Rep 122
10-27-2011, 07:24 PM | #8 |
Moon Parasite
655
Rep 1,336
First congratulations on getting your vehicle to a dyno to be tested.
But also understand that dynos can vary greatly, depending upon the type of dyno and the conditions at the time the runs were completed. So don't be too concerned with how your vehicle's numbers came out unless they're WAY off, which yours do not seem to be. The dyno is a diagnostic tool. You now have a baseline run on your vehicle so if you decide to modify it you can see how much change those mods are having from that baseline. The more important factor in all of this is in trying to use the same dyno when you test/retest to get the most accurate look at whatever changes have occurred.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
10-30-2011, 03:55 AM | #9 | |
Rep 122
I get it |
10-30-2011, 09:31 AM | #10 |
Moon Parasite
655
Rep 1,336
This was my post showing the results on my 50i after using the Dinan tune.
http://www.xbimmers.com/forums/showp...9&postcount=22
