BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
      09-04-2012, 08:36 PM   #1
jaehshim
jaehshim's Avatar
Drives: E90
Remote and Angel Eye
Just a general question...(I assume pre-lci + lci M3s all have same xenon headlight units)
My LCI 09 M3 turns on taillight and angel eyes when unlocking the door using the remote. (Headlight on auto mode)
Had battery problem recently, dealer charged it and said it was fine. The angel light and taillight do not come on when I unlock the door.
I tried everything, setting on/off on i-drive, switching auto headlight knobs around, driving and coming back and starting off/on
What's going on with this? Battery seems fine now...
      09-04-2012, 08:41 PM   #2
BMW Fanatic
Drives: slow
Have you tried leaving the switch on 'ON'? (completely turned to the right..)
      09-04-2012, 08:43 PM   #3
jaehshim
jaehshim's Avatar
Drives: E90
yea i tried every option, including having it on and turning off the car and unlocking. didn't work
I mean, technically I always leave on Auto and when i come back to the car and unlock it, it always worked (it is supposed to work that way).
hmm...
      09-04-2012, 08:44 PM   #4
BMW Fanatic
Drives: slow
Well as long as you're still under 50k miles I'd go to the dealership and have em check out what the problem is. Maybe a problem with a fuse or something.
      09-04-2012, 09:20 PM   #5
X2Board
X2Board's Avatar
Drives: I'm back, bitches! '13 E92 ZCP
That is an option that can be coded, so the dealer should be able to enable it for you.
2013 Jerez Black/Black E92 ZCP DCT - I'm back!!
2014 Guards Red 991 C2S 7MT - Gone.
2015 YMB/SS F80 M3 6sp - Gone
2011 Sapphire Black/Black E70 X5 M - Gone.
2010 Jerez Black/Black E90 M3 DCT -Gone-
      09-04-2012, 09:25 PM   #6
bluecusion
South Korea
59
Drives: X5M competition
they dont light up when battries are low or you tried few times without moving. give your car a quick drive and try it after.
      09-04-2012, 09:26 PM   #7
jaehshim
jaehshim's Avatar
Drives: E90
but this was the factory setting and i had it worked that way since i got the car. Is the coding "deactivated" due to the battery issue i had? is that the case here?
      09-04-2012, 10:03 PM   #8
X2Board
X2Board's Avatar
Angel Eyes on when unlocking the car FRM (NFRM) module.
Values: "hart_einschalten" - instant on; "soft_einschalten" - gradual; "nicht_aktiv" - disabled.
      09-04-2012, 10:14 PM   #9
jaehshim
jaehshim's Avatar
Drives: E90
I wish i could jus try it myself
just came back from the dealer today with battery issue...gotta make another appointment and another loaner for this job to be done...damn
      09-05-2012, 12:10 AM   #10
jaehshim
jaehshim's Avatar
Drives: E90
My battery shows low sign again. I knew the dealer did not charge properly, or now i can say with evidence that there is defect in battery, even after its charged it still shows low after just driving 13 miles. I'm going to get a new battery under warranty, and hopefully by then it will work again.
      09-05-2012, 06:38 AM   #11
X2Board
X2Board's Avatar
It may be the alternator, did they check the output?
m3post
