BMW X5 and X6 Forum 2014-Current
      07-18-2013, 07:47 AM   #1
1230vani
1230vani's Avatar
Drives: G05 40i LCI
Wheels from current X5 fit on the 2014 version?
I saw that the wheels being offfered as an accessory purchase look like the ones on the current (design wise). Does anyone know if the current X5 wheels will fit on the new one? Below photo is from the extras for 2014 X5.
      07-18-2013, 11:28 AM   #2
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25108
Drives: '22 Chalk Gray Porsche C2S
I don't see why they wouldn't.
      07-18-2013, 12:57 PM   #3
335Xray
Do, or do not. There is no 'try'.
335Xray's Avatar
Drives: 2011 X5 50i M Sport
Great question since I have a set of 214 style wheels and winter tires for my wife's 2011 X5 that we hope will fit on the 2014. Hope they didn't change the bolt pattern or offset...
X
2014 E63 S Model. Palladium/Black/Night Styling.
DOB 10/17/13; DOA 11/11/13; DOD 11/14/13!
2011 BMW X5 50i M-Sport: Gone but not forgotten
      07-22-2013, 09:58 AM   #4
1DRLST
1DRLST's Avatar
Drives: Silverstone X5M
They've kept the same 120mm pattern since the inception of the X5. I would assume that it will remain the same for the F15.
      07-22-2013, 02:06 PM   #5
335Xray
335Xray's Avatar
I think the rear bore of the E70 X5M was different than the rear bore of the regular X5 which made selling X5M wheels to regular X5 owners a problem...
"The X5 (74.0mm) has a different rear wheel bore than the X6, X5M, and X6M (72.5mm)"
X
      10-24-2013, 09:19 PM   #6
MtgMaster
Drives: 2024 X5 M60i
Would love to know myself. I heard the TPM might be different and that's why the roomer is they won't work but no on knows for sure. I expect to pick up my 2014 in a couple weeks and will let you know the offset of the wheels. Hopefully well find something out sooner as I'd like to have a winter set ready too.
      10-24-2013, 10:36 PM   #7
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
Every BMW model which I have owned had never had rims which will fit the next generation. Actually, I can't think of any BMW which has allowed the ability to swap rims from the previous generation. My e53 rims did not fit my e70. My e39 would not fit my e60
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      10-27-2013, 05:08 AM   #8
Mb23
Mb23's Avatar
14
Drives: It's a BM
Originally Posted by MRV99 View Post
Every BMW model which I have owned had never had rims which will fit the next generation. Actually, I can't think of any BMW which has allowed a the ability to swap rims from the previous generation. My e53 rims did not fit my e70. My e39 would not fit my e60
Same here!
      10-27-2013, 08:43 AM   #9
Genechen22
Drives: 2014 x5 50
So we are saying the old X5 rims will not fit on the 2014 or just need next TPMS?
      10-27-2013, 09:15 AM   #10
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
Sounds to me like no one knows for sure yet. FWIW, if you check tire rack, they say call for F15 wheels.. So either the wheels they have that fit the E70 won't fit the F15, or they don't know yet either.
      10-27-2013, 11:25 AM   #11
barcelona
barcelona's Avatar
Drives: X
See: http://www.xbimmers.com/forums/showthread.php?t=890933
Will the wheels from an E70 fit the F15?
The F15 has a different RDC (tire pressure monitor) system than the E70. As a result, BMW does not recommend using E70 wheels/tires on the F15.
Simple, change RDC.
      10-28-2013, 07:22 AM   #12
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
Simple, change RDC.
Sounds like maybe its a different system all together. It may not be as simple as just changing the sensors.
      10-28-2013, 08:25 AM   #13
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
Looks like tire rack now has some up. Could be worth a call to them as well as your BMW service center to see who has some concrete answers. Does look like tirerack doesn't have the TPMS sensors yet though.
      11-25-2013, 05:41 PM   #14
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
So, FWIW, tire rack told me a set of wheels I had on our current F25 X3 (18") will not fit on the new X5. Not sure if they would have fit the E70, but I thought they would. So maybe that doesn't tell us anything about the F15.
I did just get an email from a guy at Mod Bargains saying he confirmed the E70 wheels WILL fit the F15. I asked him if there were any changes to the sensors and if so, if they have the new ones.
      11-25-2013, 06:17 PM   #15
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
LOL! That's because you picked the ONLY two vehicles BMW had made with 74.1mm hub bores - the E70/71 (non-M) and the E39 M5.
As far as E70 wheels fitting the F15, it depends on the hub bore of the F15, (it appears to me to be 74.1 again based on wheels offered above which are 74.1) and the offsets - the F15 could easily required different backspacing than the E70 did, but it's also possible it will not.
I'd suggest someone tries some test fitting and post up the results. If anyone in the Seattle area has an F15 and wants to see what some 333s would look like on there, I'm more than happy to do a test fit.
      11-25-2013, 08:52 PM   #16
NoPII
Drives: 2024 XM Label
I also wonder if it makes a difference if the car has DPC (Dynamic Performance Control / torque vectoring rear axle).
I believe that all X6 models originally had this, and X5M also had it. Maybe this was the reason the rear wheels had a different hub size?
I have some X5M rims I'm really hoping will fit my F15 (with DPC)....
      12-14-2013, 01:35 AM   #17
x5x2
England
Drives: BMW G05
current x5 wheels fitting F15
any further info regarding whether they fit please, have winter 19 inch wheel set up from E70 and would great if they fitted
best wishes
      12-14-2013, 05:58 AM   #18
Deda
Deda's Avatar
Croatia
564
Drives: BMW M5 comp
Yes..it fits perfectly...i rember that dealer offered me style 232 for f15 and i have them on my x6 e71 for winter setup!
So 21 style 215 will be just for your car!
      12-14-2013, 09:05 AM   #19
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
Wheels will fit but there are new sensors, which I'm told are back ordered.
Anyone have any issues running winters without sensors? I may have to go that route or wait a few weeks, or more.
      12-14-2013, 10:14 AM   #20
NoPII
This is more confusing then. X6 uses a *different* hub size to E70 X5 (X6 is same as X5M).
So, either X5 now uses the same size as X6 (different hub sizes front and back) *or* you've got hub-centric rings on your X6 to make X5 rims fit it.
Anyone know which it is?
      12-14-2013, 10:16 AM   #21
NoPII
You'll just get warnings. Problem is that any reputable tire place will refuse to mount the wheels without functioning TPMS - they're reminded that they are liable to ensure that all safety systems are functional before allowing you to leave.
      12-14-2013, 03:02 PM   #22
chrisny
chrisny's Avatar
Drives: 2020 X5 40i
Thanks. That's what I thought. Been a while since I went without sensors, didn't know if it causes any issues since the one place I did speak to said they wouldn't mount them since they couldn't get the sensors. Said to have my local shop take them out of my stock wheels then switch back in spring. No thanks...
xbimmers
