Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      12-11-2013, 08:05 AM   #1
BMW M3 CRT
BMW M3 CRT's Avatar
177
Drives: BMW
Official M3 M4 engine specs vs Bimmerpost specs
Technische Daten BMW M4: Motor: Reihensechszylinder mit TwinPower Turbo • Hubraum: 2979 cm3 • Leistung: 431 PS • max. Drehmoment: 550 Newtonmeter • Höchstgeschwindigkeit: 250 km/h (abgeregelt) • 0-100 km/h: 4,1 Sekunden • Verbrauch: 8,3 Liter • CO2-Emission: 194 g/km • Länge/Breite/Höhe (Milimeter): 4671/1870/1383 • Kofferraumvolumen: 445 Liter • Leergewicht nach DIN/EU: 1497/1572 kg.
Has anyone noticed, that the official ccm numbers of the S55 are the same as of the N55 ... 2.979ccm !?
What does that meen for the previously in this forum leaked/rumored bore-stroke numbers/ratio ???
No oversquare engine as thought and an normal BMW undersquare N55 block instead ???
Greetings from an confused BMW M3 CRT
      12-11-2013, 08:09 AM   #2
CanAutM3
General
CanAutM3's Avatar
Drives: 2021 911 turbo
550 N-m, that is 406 ft-lb. More than anticipated...
I am also curious to find out about the official bore and stroke figures.
      12-11-2013, 08:29 AM   #3
Kadema
Kadema's Avatar
Germany
Drives: 123d
8.3l/km is 28.34mpg
431ps is 425hp
1497kg is 3300lbs (all fluids, 90% fuel, no driver)
1572kg is 3466lbs (plus 68kg driver and 7kg luggage)
      12-11-2013, 10:37 AM   #4
CanAutM3
General
CanAutM3's Avatar
The Autocar articles specifies identical bore and stroke as the N55...
      12-11-2013, 01:44 PM   #5
mkoesel
Moderator
Drives: No BMW for now
Even now, there are two threads with different displacements listed as official. One is 3027 cm3 based on the 89.6x80 cm bore and stroke numbers, and the other is 2979 cm3 (as shown above in this thread as well) which of course matches the N55 and implies the same 84x89.6 cm bore and stroke as that engine.
I have to assume Jason has his numbers correct though...
      12-11-2013, 01:48 PM   #6
Sir Loin
M3AT LOVER
Sir Loin's Avatar
Drives: Silverstone F80 M3
Is the 8.3l/km number for highway or city/highway mix?
      12-11-2013, 01:52 PM   #7
karussell
Drives: 4 wheels
this is very important because it defines which class the car competes in. which one is it?
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
      12-11-2013, 02:46 PM   #8
Kadema
Kadema's Avatar
Germany
Drives: 123d
EU city/highway mix.
      12-11-2013, 02:54 PM   #9
Sir Loin
M3AT LOVER
Sir Loin's Avatar
Thanks Kadema. That is excellent news! More power, higher mileage! That is 28.3391064 miles / US gallon.
      12-11-2013, 02:58 PM   #10
BMW M3 CRT
BMW M3 CRT's Avatar
177
Drives: BMW
Also M Power World - official webside of the M-GmbH - quotes in its official specs 2.979ccm and 84mm x 89,6mm !!!
Sorry this means for me to 100% N55 derivate or better B58 derivate ... I am nearly sure that we would see this engine in an detuned and less refined version in the next 5er series or allready in the coming 7er series
3.027ccm and 89,6mm x 80mm could also be the specs of the rumored V6 based in the S63Tu !?
f80post
